Question about Kenmore Elite 45986 Front Load Washer
Can the basket bearing in the back of the tub be replaced and where do i get the bearing sears dont show it.
    President:
  • 2,468 Answers
The reason sears doesn't show this bearing is because you need to replace the whole basket and the bearings are in there when you buy the basket,check the first 3 numbers of the model number as in a 110.xxxxxxxx will be produced by whirlpool corp as sears doesn't produce any appliance themselves,then go to that manufacturer and find their parts list and that bearing will fit a kenmore washer because its really a whirlpool front load,biut the 3 numbers before the period on the model tells you who made the machine for them
Posted on Jan 01, 2011
43142 Front Load Washer: Our Kenmore 41741042000 is 9 years old and is star...
Open up the washer, grab the metal basket and lift it up and down. If there is any play in it then buy a new washer. Replacing that spindle and bearing is not cheap. Spindle can only be purchased by also buying a new basket and that can cost $500.00 or more just in parts.
If this is what the inside drum does at all, then it is toast. Washer Spin Basket Part Number 131618500 Sears PartsDirect
This is the basket for your washer and it is $314
And if you decide to go that route then you will need the outer rear tub because the bearing is part of that tub and it is $246 Washer Outer Rear Tub Part Number 131462800 Sears PartsDirect You also have to ask yourself that since it is 9 years old, If I replace the tub and drum what else will go out? The motor? It's $120. What about the drain and re circulation pumps? Well it's $82. It will be cheaper on you to bite the bullet and purchase a new unit.
Feb 12, 2018 | Kenmore 43142 Front Load Washer
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
H3 Elite washer.... steel tub is wobbling and cutting into the plastic ring liner. If steel tub or has separated from bearing, is this covered under warranty.... after 4 years.... or not. How expensive is...
rear pulley nut is loose. tighten . if it has been loose for a while pulley may be warped and also tub bearing and spin basket could be bad. dont have your specific model # to know if in warranty . can go to wpl .com and check warranty with your model # or kenmore then go to sears.com . i would use another servicer we waive are service fee if you fix the washer we only charge 65.00 service call. im sure you can find a servicer with a lower service call. thats the highest ive ever heard they will charge you double what anyone else charges.worse case scenerio could be 300-400 dollars if tub, pulley , spin basket need to be replaced. but i say its worth you replacing pulley or checking nut any other repairs for this i would just replace unit. again check your warranty i think the spin basket has a 10-20 yr warranty.
Sep 19, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Has a squeek when it is in the spin cycle
mostly the motor problem  and other possible problem can be  that a bearing is bad.If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 08, 2009 | Washing Machines
Noisy when spinning
The noise coming from this machine as it spins is due to -- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Picture1 - Picture2
May 07, 2009 | GE WJSR2070B Top Load Washer
Maytag washer MAV551EEWW top load with loose tub
Picture1 - Picture2
May 07, 2009 | Washing Machines
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
Picture1 - Picture2
May 05, 2009 | Frigidaire Washing Machines
Clothes
check out for this link
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rear Tub and inner basket reassembly
If the shaft of the steel inner basket does not show any signs of wear such a grooves or scoring, the problem is probably with the tub shell you ordered. I have experienced this problem before on ONE occasion and had to reorder the rear tub shell. To answer your question, "No", you shouldn't have to force the shaft into the bearing, and I probably wouldn't recommend it. However, before you assume all is lost and have to resort to another order, try using some very fine sand paper or emery paper on the basket shaft to see if this will allow it to insert easier. I hope this doesn't sound discouraging.
Sep 19, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
