Question about Kenmore Washing Machines
How do I remove the top of the washer to replace the lid switch on a 110 23832100?
    President:
  • 1,554 Answers
Disconnect power then release the console from the top of the cabinet. Pull or pry off the end caps then remove the screw that secures the console to the cabinet top. Once the screws are removed, pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front andHow do I remove the - 8557e5b.jpge base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and inHow do I remove the - b27a7aa.jpgnew lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
Comment:
Posted on Dec 30, 2010
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: lid switch problem/how to remove top to repair it
The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Posted on Jul 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool MOdel 110 23832100 Lid Switch is broken, need replacing
The following link explains step-by-step how to access the lid and replace it:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
You do not necessarily have to disassemble the entire washer, but you DO need to release the clips that hold the washer casing to the back panel and frame so you can lift the case up enough to access the lid switch. The switch is mounted to the underside of the washer top panel. With the washer case installed, it can be difficult (if not impossible) to access the switch through the wash tub opening. The process is much easier than it sounds and will offer you the best access. Removing the washer case will also offer the quickest method of installation.
If you have not purchased a replacement switch, yet, you can purchase them from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. If you do not wish to order on line, this is a common part that any appliance parts retailer should carry as part of their in-store inventory. The part number for the model number you provided is 3949238.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jun 08, 2010
Testimonial: "Gott'er DONE! Thanksfor the great info!"
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
Washer lid switch replacement
there is a screw right on the edge of where the clothes go in the washer on the right side,remove the top cover ans unplug lid switch harness, remove lid switch and then replace lid switch and reverse the procedure
Oct 28, 2009 | Sport & Outdoor - Others
Lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
How do I replace the lid switch on kenmore top loading washer 23902? I can't seem to remove the back panel of the washer.
REMOVE THE 2 SCREWS ON TOP DOWN AT THE BASE OF THE CONTROL PANEL, SLIDE IT FORWARD A BIT AND LIFT IT UP IT IS HINGED IN THE REAR. NOW REMOVE THE TWO BRASS LOOKING CLIPS FROM THE TOP AND REMEMBER HOW THEY GO BACK UNDO THE LID SWITCH CONNECTOR(IT LOOKS LIKE IT GOES THROUGH THE TOP DOWN INSIDE). NOW GRASP THE CABINET AND PULL TOWARD YOU TILL THE BOTTOM DISENGAGES FROM THE WASHER BASE.NOW YOU CAN CHANGE THE LID SWITCH
Apr 17, 2009 | Kenmore 24032\24036 Top Load Washer
Lid switch
to replace lid switch unplug unit remove two screws for acess panel(runs at angle between washer and dryer)after removing acess panel you should see two 5/16 head screws holding the washer top down (at rear of top) take out these screws top should slide forward .unscrew the two phillps head screws holding switch to the top replace switch then work backwards to complete
Dec 26, 2008 | Washing Machines
GE WSJR4160DOWN
You don't have to remove the washer top. Use a putty knife to push the tabs in on the left and right side, about two inches from the sides, at the top seam of the front panel. Front panel pulls forward and lifts off bottom pegs. Lid switch has a tab you need to push toward the center of the switch (its on the back side of the switch) which will allow the switch to push up. twist the switch and pass it back down through the washer top.
Oct 11, 2008 | GE WBSR3140DW Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Help with Kenmore washer
most often the lid swtch is out of alignment, less often the switch fails
with the lid open examine the underside of the lid for the plastic 'tooth' that is supposed to engage the switch, if broken or missing replace, test
with the lid open and the washer turned on, use a ballpoint pen to engage the switch plate in the hole at the right side of the lid
If the washer starts, adjust the switch position, test
If the washer does not start
remove the edge trims from the console
remove the screws from the lower corners of the console
slide consloe forward ~1/2 inch, flip up and over
ensure cable is connected to lid switch connector
try lid switch again with ball pen
if washer does not start the switch has failed,
remove metal retainer clips from rear of washer top, remember installed position, you have to put them back
lift washer case 1 inch slide forward, lay down, remove switch
replace
reassemble in reverse order, test
3-5 times a month, takes about 25 minutes, the switch costs $7.95+tax
Aug 02, 2008 | Kenmore 15864/15862 Top Load Washer
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
207 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
