Question about K-Line Toys
Hello, I bought a K-Line 4-6-6T Boston and Albany Tank Engine. I've had the train for 2 years. Recently I noticed there was no smoke coming out of the small hole. I went through the train and I saw that the train was making smoke, but I ran the train with the top off and saw that the fan that blows the smoke off no longer works. I was wondering where I could find the small motor that drives the smoke unit fan. Also I was wondering where I could find a set of maintenance tools.
  • 5 Answers
SOURCE: Hello: Train won't move
Posted on Dec 07, 2008
  • 5158 Answers
SOURCE: Thomas the Tank Engine, Sodor Post Office Train Track
scroll down the images till you see the set that they have. click on it when the page opens look for instructions... click on that it should have them. note i did see at least one recall notice so make sure that doesn't involve the set you have
Please take a moment to rate this solution thanks
Posted on Jan 29, 2009
SOURCE: i bought the set last year of holiday lionel
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Posted on Dec 27, 2009
  • 5 Answers
SOURCE: remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
Posted on Mar 08, 2010
SOURCE: I have a 1989 echo
You take out the screw and put the oil in that hole.
Posted on Jan 05, 2011
I have 2002 frontier with a 3.3 eng. The check engine light intermittently comes on and off .When it's on the truck runs rough and smokes but when it's off the truck runs fine and doesn't smoke.And I 've ...
I would look at the EGR and the EVAP systems. Sounds like a serious vacuum leak or fuel in the EVAP. Have the codes read, this will point you in the right direction.
Feb 01, 2015 | Cars & Trucks
I have a John Wood one pipe power vented hot water heater. The model number is Jw840nvh-fv-04. Recently I've been smelling products of combustion coming out the top of the tank where the vent is.
If this heater is located in a "confined space", has the "make up air" entry point(s) been restricted/blocked? In short, is there enough air present to support combustion AND to supply enough air for the power vent to move the gases at a reasonable rate to the environment?
Can you "feel" the gases coming out the vent at a reasonable thrust? Is the power vent blower motor making any noises (not rotating properly, i.e., bad bearings)? Does the vent have any debris at the end, possibly at a screen?
Is the T&P valve dripping water? Is there ANY water on the floor? Is there a thermal blanket on the heater? Is the blanket wet anywhere? Did you recently add a thermal blanket? (Some manufacturers DO NOT recommend a blanket.) Have any liquids been spilled on top of the tank? Is anything dripping on the tank?
Is the burner flame crisp, not "lazy"?
"Recently I've been smelling products of combustion coming out the top of the tank where the vent is". There is a negative pressure present at the top of the tank where the vent is - in a properly drafting vent pipe assembly. This means that vapors, odors, and moisture ARE BEING SUCKED OUT of that area under and through the hood and then into the piping. "and when blew some smoke at the vent, it drafted up through the vent no problem". Try to identify the real source of the odor.
Lastly, I think this model uses a direct connection technique from the blower/power vent termination to the piping without a hood. So if you blew smoke at the vent, and there is no hood, how would the smoke get into the vent? If the 2" vent is PVC or CPVC, and if the gases are being slowed because of any reasons mentioned, maybe the plastic piping is slowly cooking.
Feb 02, 2013 | Water Heaters
The car I use comes with power steering but recently I notice heaviness as if it no longer is power. Nothing of the sort happened like collision, skid or rough road...why suddenly this?
Hello! Not knowing the year, make,model, or engine I can only speculate...
Power steering belt is either off or slipping, Power steering fluid tank is empty or the pump is defective...Send year, make, model and engine size...without any knowledge of the above how would it be possible to repair an unknown product?...Send information... guru...saailer
Jan 18, 2012 | Maruti Cars & Trucks
I have a 2004 Chrysler Sebring Sedan 2.4 DOHC. About a year ago, When my fuel gauge would go below 1/2 tank of fuel, I start having problems. It sputters and dies when I stop. It starts back up fine,...
Hi Angie,
I don't want to be too harsh, but you need to stop randomly replacing parts and stop putting chemicals in your fuel tank.
I have been in the auto repair business for over 36 years and that garbage that they sell at the parts stores have never fixed a drivability problem that I have ever seen. Those things are only stuff that "snake-oil salesmen" use to part desperate people from their hard-earned cash. There is no such thing as "mechanic in a can".
A seasoned, well trained, automotive repair technician with a few years of experience, can scan your engine computer, look at the data when the engine is running poorly, and give you a pretty good idea of what is causing your problem....This is what is called DIAGNOSTICS. You can spend a fortune and loose a lot of hair over trying to "guess" what the problem is.
Please also review the following articles. You may find them somewhat "enlightening".
Why Is My Engine Light On?
What Else Could Be Wrong?
Oct 09, 2011 | 2004 Chrysler Sebring
I have white smoke coming from where it seems to Problem with the Audi A6 2000 A6 I have white smoke coming from where it seems to appear, under the coolant tank, for a short period of time after...
You have coolant burning. Your 2.7T is a hot-running engine and the plastic tank sits above the left side exhaust manifold. The heat from the manifold is known to cook the tank and make it brittle enough to crack and leak. I think if you look at the tank you'll see it's leaking slightly on the manifold, causing the coolant smoke you're seeing. You can get a new tank from in Albany NY - great place to deal with (I always order parts for jobs from them) and replacement is simple.
Jul 08, 2011 | 2000 Audi A6
I have recently noticed fuel right above the sparkplug on the second cylinder on my 04 Road King. Looking for possible cause, problems and or diagnosis. Not sure where to begin.Thanks.
Fuel around the spark plug? I've never seen this before. Usually, if fuel is on the engine, it evaporates very quickly even if the engine is cold. If you notice the fuel there before you start the engine, it's probably leaking from the fuel tank or a hose above the rear cylinder head. It may be leaking somewhere up front and running down the bottom of the tank and dropping off in that area. I can say that it is probably not coming from the engine. Check for a leak in the fuel tank somewhere.
Good Luck
Jul 02, 2011 | Harley Davidson FLHRCI Road King Classic...
I bought the car used-I have to admit I didn't notice the smoke coming out the back until after I purchased it. Everytime I start the car there's a big gust of smoke. When I had brought it to have it...
Hello: Need to know the year/model and size engine. Starting some time around 2005 Gm offered a powertrain warranty of 5 years 100,000 miles. If there is oil on the outside of the sparkplugs then that would NOT indicate an internal engine problem. Your best bet would be to take the car to a GM dealer, Chev. find out where you stand
Jan 07, 2011 | Chevrolet Metro Cars & Trucks
Hello , I've a Volvo 940 1995 with a b200ft engine. Recently I've noticed that black smoke comes from exhaust & a very poor mileage about 9 miles per gallon, engine rough at idle but clears up on...
Black smoke points to unburnt fuel. I would start by replacing the spark plugs and wires if you have not done so in the last couple of years.
Jan 21, 2010 | 1995 Volvo 940
Smoke from exhaust
you put 2 many oil in the engine
Jun 01, 2009 | 2003 Saab 9-3
Toys Logo
50 people viewed this question
Top K-Line Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a K-Line Toy Expert? Answer questions, earn points and help others
