Question about Craftsman 10" Table Saw
I have a Craftsman table saw a few weeks back had problems getting the saw to run....would have to hit the switch several times to make it run. Once it was running it was good until I shut it down, then I would have to hit the switch 5 or so times to get it to run again. Today it did the same thing and now just wont run. The blade turns freely by hand and is not binded or anything. Does this sound like a bearing? Brushes?
    Problem Solver:
  • 16 Answers
Replace the switch?
Hello!
Posted on Dec 30, 2010
Hy56 replace craftsman table saw switch?
My Master Craft table saw switch quit working so i just hooked up an electrical box on the front of my machine and installed a house light switch to it. Has worked several years like this. Saved a lot of money. I rewired by using the wires from the old switch.
Apr 03, 2017 | Craftsman Saws
How to get craftsman table saw switch to work?
Getting the switch to work may involve replacement.
Nov 25, 2016 | Craftsman Saws
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Older model SI16Wa sliding table saw. Turns off after a few minutes running.
sounds like this has a thermal switch that might be faulty. What is the brand and I will try and find a breakdown, Let me know.
Mar 09, 2012 | Saws
Iunisaw stuck at 45 cant get back to 90
Do not use WD40 on anything you want able to move- it is an effective glue.
If you routinely used WD 40 on the saw- move it outdoors so you can spray the trunion with carb cleaner and then put a heat lamp on it for a while. This should soften the WD40 goo- Convair who originally developed the product stopped using it once this tendency to glue things together was noticed. They sold the rights and the formula to a former employee who made WD 40 what it is today.
It has it's uses, but not in precision mechanisms. I use it with pumice to clean the rust off machined iron table tops- that was where i found out just how strong it can be- I had just finished on saw table and gave it a light spray and merely set a 7 inch blade on the table. I came back about 2 weeks later, 1 inch of the blade overhang the 50s era Craftsman table saw- I could lift the side of the saw- if I wanted to tip the saw over just holding the blade- I could have done so. It came loose with starting ether.
you may need to reapply the carb cleaner a few times to was enough of the goo out of the trunion. Once loose again- get some 20 weight synthetic oil and brush it on- set the angle only midway so you can get fresh oil into the spaces occupied by goo as you move the arbor back up to 90 then back down to 45 then back to 90.
As I said, WD40 has it's uses, but not for anything precision.
Feb 14, 2012 | Saws
I plugged in my table saw and everything worked just fine. I unplugged it, and then came back a few minutes later and turned on the table saw again. This time the motor was not running. Power was getting...
First of all, how did you determine that power was getting to the motor? If you can test for power with a voltmeter at the motor connections themselves and show power then the switch is OK and the circuit breaker is not tripped. Turn off power and attempt to turn the blade " CAREFULLY" and if it moves easily then the motor is probably defective and will have to be replaced. After turning the motor and finding it easy to turn, then turn the power back on and try to start the saw again. Be carefull because the saw may start. If the blade will not turn then the motor is definitely defective and will have to be replaced.
Good Luck!
Mar 14, 2011 | Craftsman 10" Table Saw
I am borrowing my brothers Craftsman model 137.218240 table saw. Unfortunately, it has a on/off switch problem (I believe). Yesterday, I was able to use it all day although, at first, I had difficulty...
You can chec wiring or switch with an ohmmeter to determine if it is bad. You should be able to remove a few screws to access the inside of the saw fairly easily. You can easily by-pass the switch by twisting the wires together. Though it will have to be untwisted to shut off again. You could just unplug it. There isn't much to these.
Oct 12, 2009 | Craftsman 10" Table Saw
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Oct 06, 2009 | Craftsman 10" Table Saw
Key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Sep 14, 2009 | Craftsman 10" Table Saw
Saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Apr 13, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
96 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
