Question about Spinmaster Zoobles Small Playset with 1 Zooble Under the Sea
Zooble is stuck shut, the ears open but the eyes won't and neither will the "feet"
Samsung dual oven
what is the model number?
May 25, 2013 | Ovens
Toshiba MD14H63 dvd stuck in tray won't play region code error
Someone is going to have to open the unit and see if they can cycle the disc out by hand or not.
Nov 07, 2012 | Toshiba Televison & Video
Jen air dish washer not shutting water
Open the door to the dishwasher. there should be a circular peice on the left or right side of the tub. it maybe stuck. if its stuck. the water won't shut-off.
May 28, 2012 | Jenn-Air Dishwashers
My brakes won't "lock" when stopping and I
u need a repair manual for ur model--search online or fixya--
Oct 30, 2011 | 2008 Piaggio X7 250
My sunroof is currently "stuck" shut. If I press
alot. their is a rubber belt that runs the sunroof and in order to replace it you half to remove the head liner, remove the roof support arm then you will be into the motor
Aug 14, 2011 | 2006 Mazda 3
Hi. our little purple penguin zooble will not open. any tips? thanks.
My daughter's zooble was stuck closed and this zooble would not open even when placed on its special magnetic zooble stand. We solved the problem by sticking the cap of a pen into the back of the zooble's head to release the catch. A paperclip works too, but not as reliably. After looking at the internal latching mechanism, I would not recommend trying to force it open. She made a video to demonstrate.
Jun 20, 2011 | Spinmaster Zoobles Spring to Life Gift...
Zooble won't open.
Jan 01, 2011 | Spinmaster Zoobles Small Playset with 1...
Bose Wave... disc one will play...others give Disc Error message? Hellp
hi,
your cd players laser eye unit have some problem. its need cleaning. just open the cover. make sure that the power is disconnected. take an ear bud. clean the Lance on the pick up. u can find it inside the cd mechanism.do not use pressure cleane jauntly. do not use any harmful chemicals . it will damages the Lance. use only ear bud. after cleaning close cover .connect the power and check it. if fault remains, replace the eye unit with the same number specified in its label.
ok
Dec 15, 2010 | Bose Audio Players & Recorders
DVD drive is not reading or writing. It is 3.5 years old.
1st option is to purchase a lens cleaner and let it run through the recommended process. 2nd option is to open it and clean the lens(eye) with a ear bud with surgical spirits, but be careful not to touch the eye to hard with the ear bud, you will damage the eye beyond repair, normally it is dust that actually split the concentrated beam that read the data in several directions. disconnect power supply when working on electrical equipment
Dec 12, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
RCA DRC630N-M 12v DC portable DVD player (dual-screen). After a year of successful plays on road trips, the device only recognizes commercial DVDs 25% of the time. It will spin and wind up to speed, but...
You can clean if you open it. Just clean lens (eye) with ear stick weted with alcohol (not aceton!!!) and if it dont want to read after that, it require laser change.
Jun 11, 2008 | Televison & Video
Spinmaster Zoobles Small Playset with 1 Zooble Under the Sea Logo
1,162 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
