Question about LG Flatron W2242P-SF 22" Monitor
No matter what I connect to the monitor, it goes to power saving mode like it's sleeping non-stop???
  • LG Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 30, 2010
BenQ G2400W power save mode works find with DVI but will not go into power save using HDMI cable.
Look on the remote find the button under menu then on the screen find sleep timer or power saber and turn off.
Terry
Jan 31, 2015 | BenQ G2400W Monitor
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
Flatron W1943 sb monitor goes into power-saving mode. Does not display data.
If the monitor is displaying the "Power Saving Mode" signal to the monitor, then the monitors internal VGA board is functioning, so you can rule out a broken monitor. However I have seen monitors blow the internal fuse to the VGA board which causes a false "SLEEP" signal. If this be the case then it will require replacement of the fuse (usually a microfuse soldered onto monitor internal board) or most likely a monitor replacement.
To test:
Option A: you can connect another monitor to the monitor output on the back of the computer and see if you get a display. If this monitor goes to sleep, then it is likely that your Video card is malfunctioning. If you get a display, then it is definately the monitor.
Option B: If you have another computer, you can attempt to connect the monitor to another computer. Also most modern laptops will be equipped with monitor output, so if you have one you can check it. If the monitor sleeps, then it is definately the monitor. If you get a display, then it is definately the computer video card.
Hope that helps,
G
Sep 17, 2012 | Computers & Internet
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
LG W2261 + Windows Vista + Power saving mode
When you have access to windows, go to control panel and select Power options and change to time windows puts the monitor to sleep. You can set it so the monitor from a couple of minutes to never goes to sleep. This might help your problem.
Nov 02, 2017 | LG W2261V 22" LCD Monitor
Does samsung monitor save power in sleep mode?Or will it just displays black all over the monitor?
yes, all monitors work directly with the cpu, the cpu sends message to the monitor, so if the system is in sleep mode, automatically the monitor stops work excepts the cpu comes up again then the monitor wakes, in a nutshell, a monitor is connected to power while in sleep mode but has no signal to function
Jul 16, 2009 | Smart Modular SV3170A
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
LG Flatron W2242P-SF 22" Monitor Logo
221 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
