I have just purchased an 26" Wide LCD Tv with Digital Tv. It has searched 4 channels for me and 4 only. I have tried to seacrh again but cant seem to do so as the screen displays. Due to technical difficulties, the service you require is unavalible.Please try agan later. is this a problem with my Tv or the digital service? who can i speak to help me with this please?
  • rebel831 Jul 07, 2008
    it is an Onn Model:XQ-2623
    I have an 42" LG LCD digital Tv in the living room and it works perfect. the channels are great. This 26"Onn Lcd Digital is giving me problems, it is in my bedroom nextdoor to the living room. I live in 1bedroom apartment in high block. I dont understand why the tv oin living room works and this one doesnt, due to technical difficulties. can you not help me store my channels in? please?
  • 70 Answers
First of what area do you live in. most probable cause is that all channels are not yet available in digital format in your area.
Posted on Jul 07, 2008
How do I get channels
ok,if you have a subscription to cable,you will have a cable box,you will only need to put your tv on cable and ch 3 or 4 on your tv,you dont need to search for channels,if you dont have a subscription,then you are trying to pick up over the air channels,they are called digital channels,you will need a digital tv antenna and your hdtv,you will change the settings on your tv to air or antenna,then you can search for digital channels,there are no more analog channels like we had when we are kids,they are all digital and dont need to be tuned in,if you still cant get channels please have someone help you.
May 19, 2015 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Emerson EWF2006 TV access code
if your tv doesnt have a digital tuner, you cant, unless you have a digital to analog tuner converter (can be purchased in walmart, or other stores that carry tv s, electronics) you tune your tv to 3 or 4, use the converter box to scan for channels, and for changing channels instead of your tv tuner
Mar 21, 2013 | Emerson EWF2004 20" TV
Can't figure out indoor antenna input
first off . Indoor antennas are only good for the closest tv stations and you still have to do a channel search thru the main menu .
Oct 12, 2017 | Vizio M261VP 26" LCD TV
Programming channels for TV viewing?
You can often find the digital channel numbers for your local stations in a guide like http://www.titantv.com/ or https://tvschedule.zap2it.com/?aid=gapzap . Alternately, check if the local stations websites offer a link to their schedule. This will usually list the channel/channel digital identity. Another source for the digital channel numbers are the antenna choice/position/direction guides. Look at http://www.antennaweb.org or http://www.tvfool.com . Tvfool.com gives the direction and signal strength for all channel transmitters in your general area. Antennaweb.org is much more conservative and will only give the strongest stations in your area. That conservative list assumes an external antenna and clear path between the transmitter and your antenna.
In my area, the analog channel 7 became digital channel 7-1 . However, the channels 12 and 16 now transmit at 43-1 and 46-1 . However, after letting the TV do the auto-search, they are 12-1 and 16-1 when I type in the channel numbers on my remote.
I hope this helps. I might be able to provide a list of your local digital channels if you add a comment with your general location.
Mar 04, 2018 | Panasonic TH-42PC77U TV
I cant find the code to program my wide open west remote control to turn my Vizio TV on and off
SEARCHING FOR YOUR CODE
1. Turn on your TV.
2. On the remote control, press TV once; it will
blink once.Then press and hold SETUP until
the TV key blinks twice, then release SETUP.
3. Enter 9 - 9 - 1.The TV key will blink twice.
4. Aim the remote control at the TV and slowly
alternate between pressing PWR and TV.
Stop when the TV turns off.
5. Press SETUP once to lock in the code.The TV
6. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or CBL)
for the device you are searching for.
http://www1.wowway.com/remotecontrol/
Good luck, pls rate it :)
Dec 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Why do i only get 4 channels that show?
sir you need to auto search your t.v set or auto program it to get all channel you desired.
Aug 06, 2009 | Coby TF-TV2617 26 in. LCD TV
Hello. I am contaqcting you for my mother. My brothers recently purchased and insignia 26" LCD NS.LCD26. I have run it through the auto scan program, and she receives the digital channel 18-1 but on...
Are you useing rabbit ears? If so you may have to switch to an outdoor antenna to get those channels ( the digital signel is a better picture but the signel is not as wide as an analog signel so in most cases you will need an outdoor antenna!)
Also make sure your tv is in the antenna mode and not the cable mode!
Please rate this response
Thank You!
Jan 23, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Lost ITV channels and C4
I've got exaclty the same problem :-/
HELP!
Oct 06, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
Televison & Video Logo
Top Televison & Video Experts
