Question about Briggs and Stratton 020275 Elite Series 3400 PSI Portable Gas Pressure Washer
What are the valve clearance settings for the 10 hp Briggs & Stratton Motor.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Briggs Master
  • 1,411 Answers
PartsTreeRepairClinic will help with that
Posted on Mar 04, 2018
5 Suggested Answers
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Posted on Apr 23, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
  • 57 Answers
SOURCE: Briggs & Stratton engine on my Craftsman
try changing the spark plug.
Posted on Dec 20, 2010
  • 1267 Answers
SOURCE: The 6.5 hp Briggs & Stratton engine that
It most likely is a ring problem as the gasket only keeps the combustion gases in and would leak around the head as a loud noise. Of course it could be the valves, but I doubt it as most of these engines are splash fed instead of pressure, so the only explanation is the compression ring is letting oil blow past.
Posted on Jan 03, 2011
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have briggs and stratton 5.5 hp motor model 12h702.And oil comes out of the breather.Could it be the valve guides or the rings. It smokes out of the breather hose and exhust a little.
It sounds more like badly worn rings and/or a glazed bore. Provided bore is not badly worn, a bore hone and a new set of rings should solve the problem. While yuo have the engine apart, a valve grind and check/adjust of the valve clearances wouldn't hurt.
Sep 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Intake valve & exhause clearance
3000 or 4000 is your clearance, get the piston up top dead center make sure piston is to the top of the cylinder rocker arms should be level with each other before you set them
Jun 05, 2010 | Swisher T14560 T - 60" Trailmower with 14...
Have a 20hp vanguard on a go-devil long tail motor. engin runs at idle speed then when i put the propeller into the water it stalls. if i pull the choke and give full throttle it will run some and backfire
These engines seem to have problems maintaining the correct valve lash settings. try taking the valve covers off and checking the valve/pushrod clearance.on tdc compression stroke it should be .001-.003 clearance. then check exhaust stroke tdc on exhaust stroke. clearance should be same on the other valve then. hope this cures your problem.
Dec 22, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 020275 Elite Series 3400 PSI Portable Gas Pressure Washer Logo
94 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
