Question about Motorola Mobility PEBL U6 Cellular Phone
Motorola PEBL I have had my phone for 2 years and taken relativity good care for it apart from the occasional dropping,banging ect. Recently my sound dosen't work the sound says it is playing but no sound is coming out, I have tried turning the sound up ,the phone off and back on and taking the battery out. Any Ideas Will be Appreciated Thanks
  • mbll Jul 27, 2008
    Phone will not ring or vibrate, regardless of volume setting. It is not
    on silent. Every once in a while it will ring when call comes in, most
    of time not. Does do "event reminder and "alarm" chimes. Tried
    turning off and back on - does not work. Two options are:
    1) master rest (which probably has some downsides) 2) making sure
    to turn it off for atleast 10 minutes a day (says TMobile) Any
    one tried either?
  • Anonymous Aug 25, 2008
    Have exactly the same problem (alarms sound, etc) but won't ring or vibe to incoming calls. Haven't tried master rest or 10 min/day rest, will try and let you know.
    Brigadier General:
  • 7,752 Answers
Replace the speaker on the phone to correct this issue
Posted on Oct 01, 2008
Need unlock code for a motrola pebl
Get the unlock code for your Motorola PEBL U6 model mobile here http://www.theunlockspot.com/motorola-pebl-u6/rs10wp9/ , it gives the easy instructions for getting the code for your mobile ........
Nov 29, 2011 | Motorola Mobility PEBL U6 Cellular Phone
How to change lcd screen on motorola pebl u6?
As on most Motorola phones, the lens that covers the main LCD must be carefully removed to access the screws underneath to pop off the exterior faceplate. Once that is done, there is a silver main casing that protects the LCD. Pry up the side to remove it. You will then be able to access the LCD for removal.
Mar 11, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Takeing off cover of motorola pebble
You have to carefully pull the lens off of the screen, it just has some light glue on it and under the lens there is 2 #6 tork screew
Apr 22, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl u6 fitting new housing instructions
There ares 4 screws (#6 torq) on the back side where you replace the battery. take those out and the phone come apart. Be carefull because the main board, key board and all will come apart with careful prying. Also watch out for the ribbon cable that connects the LCD screen to the main board
Apr 05, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorola peble troublshooting
you will have to call the T-Mobile Help desk and have one of the CSR's assist you with the issue.
Feb 24, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorla PEBL not ringing
Okay Ive had this phone.
Do any other sounds on there work?
such as music in the sounds area?
Or Sounds in games?
If NOT I would think that the internal speaker has been damged by the water.I would try and get it repaired by motorola,or under warrenty.
If these sounds do work,and it is only just that there is no sound when you get msgs or calls,check your phone is set on a loud style,rather than silent or vibrate.Normally you can change this by going to Settings and icoming call alerts if im remebering right.
Or I Think you you can change it by the side buttons.
Hope Ive Helped You Out.
Good Luck With It.
Sophie x
Feb 14, 2008 | Cell Phones
I dropped my Pebl and now camera wont work properly
Bring it to your local service center, the camera module is broken. Part needs to be replaced. Its easy if you want to do it your self, but i suggest you bring it to your carrier or moto service center. If you dont have a local Moto service center near by, or you wanna get the part and do it yourself, check my profile and im sure we can help you out.
Jan 11, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl
the conections inside the LED are alreardy loose..maybe bec. u accidentally dropped ur phone try to visit a cel repair shop they wil resolder the loose connections inside you phone..
Nov 09, 2007 | Motorola Mobility PEBL U6 Cellular Phone
My motorola pebl wont ring but I can play the ringtones manually. Help
Well look on your settings and set your ringing volume to full . check your phone for any settings that may affect your fone ringing . e.g make sure it isnt on silent , Hope i helped
Oct 16, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola PEBL U6 Cellular Phone
There could be corrosion on the actualy board or something could have been shorted out. Get a new one.
Jul 01, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Mobility PEBL U6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
