Fixing flatpanel tv
The monitor is blank all it shows is a white screen. Can someone assist me with this problem?
  • 5,568 Answers
What you are seeing if it is an LCD type, is unattentuated light from the backlight with none of the pixels active.
It is likely that a service voltage has died disabling the matrix that controls the display.
This is not likely a do-it-yourself problem.
Posted on Jul 07, 2008
White screen
"White screen" on Samsung LED TV - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from www.cnet.com
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
Why is my Philips brillance 220cw Monitor showing white screen?
that is what we can assume . some can be repaired most can not
Jul 28, 2015 | Philips Computers & Internet
Hiteker tv codes
i have white screen on this tv no matter which input it could be on cable /tv or hdmi, dvd,etc tv stays on white screen but audio is good.. how do i fix this??? the tv dont show channels changes or setup when using control just a blank white screen.
May 11, 2013 | Polaroid Hiteker Msav2611 Msav2611-k3 26"...
Screen is white
OK, two possible problems but first, turn off and unplug everything.
Set everything up and try a different monitor (borrow one from a friend or plug into flat screen tv)
If this gives same result then your graphics chip is dead. Replace graphics card.
If your pc doesn't have a graphics card to replace then there's probably something else wrong on the motherboard so you'll probably need to replace this.
If it does work on a borrowed monitor/tv then you monitor is faulty and needs replacing.
Jan 19, 2013 | Samsung SyncMaster 740N 17" LCD Monitor
Computer monitor is white
What do you mean, white screen?
It just went blank after a few minutes of use?
Anyway, you've already eliminated the monitor as the surce of this problem, so it can now be either the cable from your monitor to your PC or your graphics card. I suggest you try another monitor, and if that doesn't work, find someone to temporarily insert another graphics card into the system.
One of these should fix the problem,
Yannick.
Jun 16, 2009 | HP Pavilion F1703 17" LCD Monitor
Montor shows a blank white screen and is unresponsive
Please try to connect the monitor to another PC, if it continues to happen, then probably an internal electronic part/s of your monitor is cold soldered / defective which failed to send signal to other hardware parts of your monitor thus you only see white display. I suggest to bring the unit to an authorized service center fix / replace the cold soldered / defective part/s. regards
May 28, 2009 | Dell Computers & Internet
The montinor is white
Chek the conection on the monitor,open the monitor and chek th conection of the lcd if is conected ok.i had tht problem to,and so i fixed.
Jan 17, 2009 | Hannspree HW191D LCD Monitor
Kworld pc to TV - avi does not show on TV screen
This turned out to be due to weirdness in my laptop's onboard graphics card. If I set the external monitor to display the way an external monitor usually does, as a clone of the laptop screen, the videos show up blank. But if I set it as dual-screen (extend my desktop to this monitor) and drag the video app onto the second monitor, it works fine.
Jan 07, 2009 | KWorld PC to TV (0872880887527) Video...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Red CRT monitor
Yes, absolutely know that one. It is a problem with the hardware in your monitor. I had the very same problem, there is no tuning or anything else thats going to fix it. Hopefully, you are still under warranty, well since it's six years old probably not. Since LCD flatpanel have dropped dramtically in price, I suggest you get a new LCD. The cost and trouble to fix it just isn't worth it. Best.
Oct 26, 2007 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
