Question about Belkin (F5D7230-4) Router (587009)
My Belkin F5D7633-4A ADSL2+ modem with wireless router is disconnecting from the internet with increasing frequency. To reconnect I pull out the power cable feeding into the back of the router and after 10 - 20 seconds plug it back in and once the router goes throgh its startup sequence I am once again connected to the internet. I have a cable connection to my desktop computer and have two laptops which have wireless connection to the internet through the router. Disconnects never happened and then occured very infrequently, but recently they are occuring several times a day.
  • 536 Answers
There could be a number of things going on. I'll list some of them that you might check:
  1. Your wireless network does not have security enabled, and your neighbors are using it to download files using P2P networks. These P2P network connections are crashing your router. In order to resolve this issue, enable WPA or WPA2 security on your router per the user manual.
  2. One of the filters on your phone line has been removed or is failing and needs to be replace. Remove each filter on each line one-by-one and run your Internet connection for a while to see if it fails. Do this one-by-one for each filter.
  3. You recently started using 2.4GHz cordless phones in your home. Get rid of these cordless phones and buy DECT 6.0 compliant cordless phones that use a different radio frequency.
  4. Check the wiring of your telephone jacks to make sure that the connections are solid and that there is no corrosion on the connection. Verify that all jacks and cords are undamaged
  5. Call your DSL provider and complain that their service drops-out on a regular basis.
Hopefully one of these suggestions will fix your issue.
Good Luck
Posted on Dec 30, 2010
I have a WAG320N modem router now my internet is disconnecting
You can try by resseting and re configuring this router or alternatly you may need to replace your router because this is a common problem with router of such series.
Apr 21, 2013 | Linksys Wireless-N Home ADSL2 Modem Router...
Belkin G Wireless 3BC117 stopping working - screen message says no wireless signal found in area. How do I check router settings?
Did you change the modem?
Did you have a power surge/blackout.
Are all lights on router on?
You need to reset your modem by unplugging the power for 30 sec.
Unplug power from router. Reconnect modem and power in that sequence and see if it reconnect to the internet.
Feb 07, 2013 | Belkin Computers & Internet
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot connect to internet with ps3 using belkin g plus mimo..
you might need to disconnect your modem for 30 secs then reconnect it . i have just reset my router and then the pc would show a connection but it only went to the router not through to the web.disconnect your modem reconnect then do a reconnect on the pc
Aug 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router disconects from modem-Belkin router/Wildblue modem
hi,
try to chk out the firmware of the router. in most of the cases firmware are the major problem for the disconnection of the connection if the device has been purchased a while ago. visit ur belkin website and look for the firmware for your router model no.
if the device is new then try to decrease the mtu size and temporarily disable the firewall of the router
gud luck
thanx and regards
sukhiii
Aug 19, 2009 | Belkin (F5D5231-4) Router
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
I am replacing BT 105 modem with a Belkin adsl2 modem with wireless g router. The 105 has a blue cable with a square connector. I tried to put the yellow supplied cable in the back of my computer but it...
no, but you need to configure the router to connect to the internet, you should have a "quick start guide" that will help you connect to your router and set your ADSL dial settings (as it needs this to connect you to your internet service)
once these connection settings are set you should be able to connect to the internet
you can then explore the other settings including the wireless configuration of your router
Oct 03, 2008 | Belkin Computers & Internet
Signal strength very low. Belkin ADSL2 modem with wireless g router F 507632-4
signal is bouncing off doors and walls to get to your comp
move comp closer to modem if it increases and your signal strength increases then you know youll have to be close to modem
other problem someone taped your signal and it working off of it call your provider to come out test the wireless signal strength and or password your wireless router settings so some one cant interfere with signal
i dont like wireless myself in the home i go straight cable with ether net cord this always has strenght and cannot be tapped
May 09, 2008 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
301 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
