Question about Watches
I can't figure out how to change the day and date on the watch.
  • 4 Answers
SOURCE: Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Posted on Nov 14, 2007
  • 14 Answers
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Posted on Dec 01, 2007
SOURCE: watch 3 dials inside face
so its a chrono watch i belive. well sometimes diffrent models require diffrent operations to set up the display.
Perhaps the manual can be found on the internet site of the watches brand.
Posted on Mar 18, 2008
  • 37 Answers
SOURCE: HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Posted on Nov 24, 2008
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
How do you change the day of the week and the date on Vintage rose 6752
Push in that small indentation with a pin tip until it's on the date you want, quick , but took me 4 months to figure out...
Jan 12, 2014 | Invicta Mens 6752 Vintage Rose Dial Black...
Timex day does not change
see a jeweler and the can fix
Oct 07, 2012 | Watches
How to adjust day?
If the day is in a window next to the date, pull the crown out one position to the same position used for the date correction. Often turning one way changes the date, turning the other direction changes the day. If your day is on a small dial on the watch dial then pull the crown out two clicks and go around 24 hours at a time and you will see the day advance.
Dec 18, 2011 | Cerruti 1881 Watch
How do i set the date on my nixon sentry
The notch has two positions. when you pull it out completely that is the time adjustment. Now when you pull it just slightly that will be the date setting. Turning it clockwise will change the day and counter clock wise changes the date number. Hope that helps.
I got my watch from a third party w/ out manual cause it was cheaper. Took me awhile to figure out.
Nov 13, 2010 | Nixon Sentry Watch
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
Dkny 1350 how to change day
Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
May 25, 2010 | DKNY 1009 Wrist Watch
I can't figure out how to set the date.
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Apr 26, 2010 | Fossil BQ9183 Wrist Watch
Mar 14, 2009 | Fossil BQ9183 Wrist Watch
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Watches Logo
27 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
