Question about Kenmore 44102 Front Load Washer
I have a front load Kenmore washer,model 417.44102300 . The fabric softener dispencer is not working. I did pop out the drawer and cleaned the port hole out , and it was clogged. But, cleaned out the inside of the machine slot where the drawer is installed. Still will not dispence fabric softener. Help please
SOURCE: Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Posted on Oct 28, 2006
SOURCE: Bleach and Fabric softener not dispencing
One thing that I did was to clean out the filters on the inlet hoses.  This increased the water pressure to the machine and improved the situation.  I am still having trouble with the bleach dispenser.
Posted on Oct 10, 2007
  • 6 Answers
SOURCE: fabric softener dispencer
The inlet for the softener may be plugged. Try a toothbrush to clean the area.
Posted on Jan 14, 2008
SOURCE: Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Posted on Feb 03, 2008
  • 24 Answers
SOURCE: Fabric conditioner dispencer not working
Dispenser trays have a narrow hole at the base of the unit.. this is most likely blocked with gunge... pour bleach into outlet and push a straw through to clear obstruction. Once cleared take drawer out of machine regulary and wash in hot soapy water to prevent a repeat buildup.
Posted on Aug 02, 2008
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Our Kenmore HE 2Plus Front Load washer model # 110.475*4753 is haveing an F03 Error and we can not get it cleared. Any ideas? We have hit stop twice, and cleaned the hoses, nothing clogging them..help
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 13, 2010 | Kenmore Elite 45986 Front Load Washer
How do I get my Kenmore Elite model #20056 it beeps f3 error code
Jun 24, 2010 | Kenmore Elite 45986 Front Load Washer
Describe your Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer Problem: F03 error message. Not clogged - anything else we can do?
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Oct 10, 2008 | Washing Machines
Kenmore Elite fabric softener won't drain
Is the dispenser full? It could be that it is a bit clogged. I would try just pouring a little very hot water in for several loads and using dryer softener sheets during this time. Let's see if we can unclog it .
Aug 21, 2008 | Kenmore Elite 45986 Front Load Washer
Fabric softener dispencer
Jan 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 08, 2007 | Maytag Neptune MAH6500A Front Load Washer
Kenmore 44102 Front Load Washer Logo
161 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
