Question about Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle
When I turn the turrets they go in the reverse direction, WHY
  • 2,418 Answers
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Thats just the way it works. Point your right index finger at a spot on the wall, and sight down your finger like looking at sights, then take your left index finger and pretend it is a horizontal cross hair above your shooting finger, then raise your left finger a set amount above the right, then move your hands back to the shooting position not changing the distance in between, using your left finger now as the sight. You will see your shooting finger is now pointing lower than before. This is now the new point of impact, lower not higher. Hope this is clear as mud and helps Fix Ya up.
Posted on Jun 11, 2011
91 Nissan truck 5spd transmission , only gear that works is reverse and 5th gear, doesn't have a reverse Lockout or a reverse sleeve. Trying to rock back and forward of truck no luck, any suggestion?
if the gear lever is into the top of the box, remove the turret and pivot ball and see why the shifter rails are not lining up
if it is a column shifter , check all linkages for adjustment or fallen off
Jan 02, 2017 | Nissan Cars & Trucks
2001 Hyundai Tiburon will not go into 5th or reverse, however it will go into gear 1 to 4
5th and reverse gears are on the same selector rail. It is possible that the selector fork has come loose for the 5th gear or reverse. Remove the gear lever turret section of the box and see if the selector rail is moving gears or the rail itself.
Dec 08, 2014 | 2001 Hyundai Tiburon
My holden viva 2008 manual cannot put into reverse
as the 5th gear and reverse gear are on the same shifter rail the there may be a problem with the selector fork for reverse gear. Undo the bolts that hold the shifter turret to the box and see if the reverse selector moves when you use a lever to move the rail
Sep 28, 2014 | Cars & Trucks
Where is the backup lamp switch in a 69 Ford bronco with a 4 in the floor trans???
reverse switches are located in the side or end of the gear box in line with the reverse shifter rail. or in the selector turret where the gear lever can push it when in reverse.
Jul 26, 2014 | Cars & Trucks
Seized gear box.
check the selector levers for wear and possible jamming or if you have the lever directly into the top of the box then check the lever pivot pin in the turret of the gear box.
May 03, 2014 | 1990 Mitsubishi Minivan
Vauxhall vectra problems
check the pivot pin for the gear lever at the turret at the top of the box. you can check the shift rail operation her if you take the turret section and gear lever of the top of the box.
Jan 03, 2014 | Cars & Trucks
Hi I sighted inmy rifle today with a Ziess Conquest scope. When i needed to bring the point if impact up . The impact moved down instead. I turned the scope turret to the right like the markings on the...
I hate those 'direction' arrows. I usually end up ignoring the arrows and moving it however it takes to get what I want.
Raising the crosshairs will cause you to have to point lower to make the round hit on target.
Oct 12, 2017 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
How do you reset W&E back to factory "zero",
Step 1 - Turn one adjustment turret all the way to one side,
Step 2 - Turn it back the other way, counting each click,
Step 3 - Turn it back in the original direction 1/2 the total number of clicks you counted in step 2.
Step 4 - Repeat with the other turret.
Nov 02, 2010 | Bushnell Banner Dusk & Dawn 6-18x50...
Top turret sticks
Remove numbered turret, check stem for dirt or grim...if it turns hard send it to Premeir under the warranty or email scopeshooter AT yahoo DOT com
Apr 06, 2010 | Leupold 54690 8.5-25x50mm Mk4 Lr/t M1...
Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle Logo
343 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
