Question about Nokia Intrigue 7205 Cell Phone
I've had my Nokia intrigue 7205 for over a year now and recently it just had a big problem. Everytime I try to enter the Menu. the phone would turn off and back on. I've tried turning it off and taking out the battery but still., it shuts down when i try to enter the Menu. It also turns off when i receieve texts but i can send texts. I can send one call and after that it shuts off, but i can recieve calls as well. So basically everytime i try to enter the Menu or messages, it turns off.
  • 2,133 Answers
Software problem. Check with Nokia service station.
Posted on Dec 30, 2010
Nokia 7205 intrigue draining battery
You will need to turn off the Wifi on the phone, as it searches new places to connect it sucks power. Simply turn off the Wifi in the settings menu and let us know how the phone performs over a 48 hour period.
Nov 21, 2013 | Nokia Cell Phones
Nokia 6162 codes
1. Switch your 6120C off and then on again using the power button on top of the phone. A "Lock Code" screen will appear if the phone is locked.
2. Enter your lock code using the number buttons. The default code is "12345." If you enter the wrong code five times in a row, the phone will ignore all entries for five minutes, after which you can try again. See Tips for more information.
3. Press down the "Scroll" key. The phone will unlock with the right code, enabling you to make phone calls and send messages.
Aug 19, 2012 | Nokia 6161 6162 6650 fold 7205 Intrigue...
Remove sim card on Nokia 7205
how to i find sims card in my nokia 7205
Feb 21, 2012 | Nokia 7205 Intrigue Holster wSwivel
Phone will not stay on. It shuts down, restarts,
This is a KNOWN problem with this phone.
Read all of this answer before deciding what you want to do. You'll have several options:
To correct the problem yourself you'll need to have another (older) phone (not a 7205 Intrigue) that your phone number can temporarly be transferred to. Then, follow these steps:
1. Assign your phone # to a different device using its EIN.
2. Startup the other phone and make sure all text messages & other undelivered stuff is picked up by the other phone.
3. Turn the other phone off, reassign your # to the 7205 Intrigue, and start it up. Problem solved!
Some key points:
- you can do this yourself on Verizon online--if you have another operable device to switch to; otherwise, you can go into a Verizon store and have them switch to a test phone for you. Obviously, the other phone cannot be a 7205 Intrigue.
- after switching your # to this new device, you MUST wait SEVERAL MINUTES and confirm that all the msgs floating around in the system while your Intrigue has been malfunctioning are delivered to the new phone.
If you switch back and forth too quickly the problem will NOT be solved.
Nokia is aware of this problem and sent a bulletin on 7/30 stating that the bug will be addressed in the next software release for this phone (no target date specified.
Intrigue owners will not receive any notification when this software release is available, and that the phone will have to be brough to Verizon to have them load the update.
Unless you're attached to the Intrigue, exchange your phone for a different model and avoid this headache! (That is, of course, if you kept the original packaging which Verizon requires for exchanges of even faulty, nonfunctional equipment.
Call verizon, and see if the software update has been released. a. If so, go have it installed on your phone.
b. If not, do the EIN switch. If the problem happens again, go back to step II.
Apr 08, 2010 | Nokia Intrigue 7205 Cell Phone
Need programming codes for Nokia 7205
Is there a specific reason you need the code? The following are the most common nokia programming codes: On the main screen type in:
*#06# for checking the IMEI
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation.
Hope this helps, Joe
Feb 19, 2010 | Nokia Intrigue 7205 Cell Phone
Nokia Intrigue 7205 Cell Phone Logo
171 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
