Question about Tools & Hardware - Others
I have a Fasco pneumatic framing nail gun. My problem is when I fire a nail the drive pin will not retract back into the cylinder. How can I fix this?
rowdy45176
  • 2176 Answers
SOURCE: Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Posted on Jan 01, 2009
jj505
  • 195 Answers
SOURCE: Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Posted on Apr 09, 2009
  • 548 Answers
SOURCE: The Senco SFN-1 gun will drive one nail and then not retract
sounds like time for a rebuild i do this once a year on all of my guns i buy a seal kit and replace them at that time and oil the interior oparts and check for worn or broken parts
Posted on Sep 03, 2009
rcalorisian
  • 313 Answers
SOURCE: nailgun firing pin not connecting with nail
  • you need to make sure the guns is clean and oiled
  • make sure you are using the right kind of nails
  • some perfer the ones connected my wire and some the ones connected my paper.
Not knowing what kind of gun you have that is the best I can do..
Posted on Sep 08, 2009
SOURCE: When I fire my im250 the firing pin often does not retract
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
Posted on Sep 14, 2009
Pneumatic framing nailer firing pin
sounds like you need to replace the oring around the firing pin piston , or replace the oring or band around the cylinder that the firing pin goes in , it should be the smaller oring that has tiny holes behind it when removed
Sep 22, 2012 | Ridgid Air Tools & Compressors
I have a Hitachi nv 83 nailer,the firing pin sometimes does not return all the way back in,I have pushed it in with a screw driver and it only works for a short while.Any help it would be much...
Are you oiling your nail gun, it sounds like it's suffering from a lack of lubrication? It doesn't take much pneumatic tool oil but nail guns have to have it to work for any length of time. If you have been oiling the gun, you may have o-rings inside the gun that are worn, broken, or blown out of place. You can remove the head and check the condition of the o-rings and see if the inside of the gun is dirty. Clean the gun up and pay partucular attention to the o-rings on the bottom half of the cylinder and piston. When reassembling the gun be sure to grease the o-rings well. If you still have the same problem you may have to rebuild the gun by replaceing all the o-rings. Unfortunately Hitachi does not make rebuild kits so you have to go to their website on an aftermarket site like www.ereplacementparts.com and order each and every o-ring.
Jun 26, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Dewalt framing nail gun The hammer stopped re-cioling any ideas?
On pneumatic nailers, this is usually a sign of worn or broken o-rings inside the gun. If the driver isn't retracting it's usually caused by the o-rings on the lower half of the cylinder or the piston ring.
May 21, 2012 | Dewalt Tools & Hardware - Others
Dewalt 51822 framing nailer acts like trigger is stuck. After I fired a nail the piston did not retract and there is air coming from the exaust. I disconnected the air supply and removed all the nails to...
Generally when the trigger makes a pop sound when you fire the gun and driver does not activate is indication of failed orings. There are two orings on the trigger firing pin and two orings on the cylinder that are made of vinyl and fail. All the other orings in the gun are black rubber like compound and last for a very long time. The two orings that fail within the gun are included in the repair kit and the trigger valve will most likely need to be replaced, or you could remove the valve and change out the two small orings (2 x 1.5 mm). If you would like to attempt repairs, email and I will give you detailed instructions. Main problem is that the replacement orings will be vinyl also and will not last very long. Good luck
Jun 09, 2011 | Dewalt D51822 Clipped Head 2Inch to...
Our Bostitch RN46 coil nailer was bought new last July and has only put on around five squares of shingles. We used it today for the first time since last summer and at first it was mis-firing, only...
Going strickly by what you said above, it sounds like you put it away 'dry'. If you are not going to use a nail gun for an extended period of time you should lube it well with pneumatic gun oil and fire a couple nails to distribute it throughout the gun. When you take it out of storage, put a little more pneumatic gun oil in it and fire some nails to get it well lubed again and blow out any excess oil. WD-40 is OK on the exterior of the gun as long as you blow off any excess after spraying it on; never use it inside the gun. The problems you are experiencing now are indicative of broken or damaged o-rings inside the head. Some of the o-rings act as seals and some act as valves. There is also a rubber bumper at the bottom of the cylinder. When the driver hits the bumper it is pushed back up by the rebound off the bumper and assisted by air pressure. If one or more of the o-rings are damaged the air isn't directed to the proper place to make these things happen. Bostitch makes a rebuild kit for your gun. It's part number RN-46RK. You can find them on several on-line after market sites and should cost around $30 to $35. Use all of the parts in the kit and you'll have a gun as good as new.
Mar 18, 2011 | Stanley Factory Reconditioned Bostitch...
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
My craftsman framing nailer has two nails jammed in head. Is this something I can repair myself?
Yes, just disconnect the air line and get in there and dig them nails out, don't wait for somebody else to work on it. Do it yourself. The front of that gun should lift up and expose the nails coming through, pull them out with pliers, make it clear, then reload and fire it back up and see what happens, a lot of times the generic nails will clog up.
Oct 10, 2010 | Nailers 3 12" Pneumatic Air Round Head...
I have a paslode straight finish nailer, purchased in Australia around 2001. The problem is that the pin that drives the nail out of the gun does not retract back into the cylinder. I have it apart and the...
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
Sep 15, 2010 | Omega Paslode 901000 Impulse Cordless...
I have a Bostitch BT200 that is dry firing. It seems that the "hammer" is not retracting after it fires a nail. I have to push it back manually and even then it seems to dry fire a few times before a nail...
The check seal is what causes the piston to retract. Remove cylinder and examine check seal. It is a small band that covers a series of holes and should fit snuggly around cylinder. Other factors that have effect on piston retraction are, split/cracked cylinder, bent driver and lack of lubrication. This gun is tricky to rebuild. Make shure that all the parts in the head are placed correctly. The kit does contain all the parts that you need. Good luck
Sep 07, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
Tools & Hardware - Others Logo
49 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
