Question about Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744 (PSATX25012E) Power Supply
No power supply power out, ps fan not coming on, fuse is good
  • Gateway Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Posted on Dec 30, 2010
Al-a250atx does not power on
replace power supply if it's faulty
Nov 13, 2013 | Computers & Internet
When is the power supply fan supposed to come on?
as soon as the PSU is turned on the fan should start if it doent the PSU is faulty
Dec 15, 2011 | Dell (PS-5251-2D) (PS52512D300WB) 300-Watt...
I have an old Hp Pavillion 505n desktop computer. Has been working fine for years. Awhile ago it would not turn on at all. The disk drive lite would flash on and off a few times then nothing. I removed the...
That 4 pin plug generally supplies power to the processor. It depends on the processor type. Unfortunately the next step in troubleshooting is to replace the motherboard or the processor and there really isn't a good way to know which one first.
Jul 29, 2011 | Computers & Internet
Power switch light is on but no other poweris getting through, changed the power supply but same problem. light comes on power button but power supply fan doesn't even come on.
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Sep 26, 2009 | Packard Bell (190169) Power Supply
No power output from powersupply.
Power supplies are not meant to be repaired, as you can easily hurt yourself since the capacitors hold charge. If the fuse is good, and you reset the power supply by unplugging it and then plugging it back in and it still will not provide power, trash it.
Jul 19, 2009 | Lite On (PS-5101-2B) (ps51012b) 145-Watt...
No power to motherboard
Could be one of these:
1. Lead Fuse could of blone
2. Fan broken
3. Insted of the power, it could be your motherboard
4. THE WHOLE THING
Im sure your get it fixed soon and i hope me telling you what it could be has helped you.
DigicalJAI
May 19, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
Won't turn on - PS light on but no PS fan
Surely sounds like the power supply is in need or replacement, or fuse replacement at absolute least.  the fuse that you will be in search of will be located inside of the power supply unit.  Use caution when working inside the power supply.  If you don't see a fuse in the power supply, OR you come to find that the fuse is not damagaed then you will likely need to replace the power supply.
Regards,
Joe
May 07, 2009 | Computers & Internet
AA8 DuraMAX won't power up
if you are sure that the ps is ok replace the motherboard
Mar 21, 2009 | Abit AA8-DURAMAX Motherboard
Screen goes black immediately after astar logo screen comes on
Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 21, 2008 | Astar LTV-3001 TV
Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744 (PSATX25012E) Power Supply Logo
163 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
