Question about Sharp Office Equipment & Supplies
This unit is a Sharp AL-1651cs copier. I am getting a light and fuzzy space at the same point as the drum rotates. Is this a deffinite sign of needing a new drum or am i wasting my time with this unit?
  • tucker711 Jul 07, 2008
    I will try it and find out
  • 6,487 Answers
You just really need a new drum for this one to make it work fine again..because that fuzzy space is just a sign of bad drum.
Hope that helps.....
Posted on Jul 07, 2008
Sharp AL-1651CS Color Copier, error e7-11
Is the lamp lighting when it codes out? If no, replace light source #1 (the whole moving part of the scanner).
Jan 06, 2012 | Sharp AL-1651CS Color Copier
I need help downloading the driver for my printer Sharp AL-1651cs
Go to this site. It's in Poland:
http://esupport.sharp.pl/html/driver/index.php?StartRec=0&ListLimit=10&TemplateLang=en&Lang=%&ProdLine=34&SortOrder=DESC&OrderBy=Title&OS=%&EMU=%&SearchString=
Jan 11, 2011 | Sharp AL-1651CS All-In-One Laser Printer
I can't find sharp ar153e n driver for windows 7 64 bit
 Here you can find all about Sharp AL-1651CS like driver and other information www.ps2netdrivers.net/driver/sharp.al-1651cs
Jan 10, 2011 | Office Equipment & Supplies
Fusing unit does not heat up
My Canon PC795 copier returns EO when I try to power it on. The unit does not power on. Please HELP!!!! Thanks.
HUGGER
May 29, 2010 | Sharp AL-1651CS All-In-One Laser Printer
I HAVE A SHARP AL 1641 CS COPIER AND THE DRUM I WAS GIVEN WAS SHARP AL 1000 DRUM UNIT AL 100 PART MS1DR AND THE DRUM LIGHT IS STILL ON AND THE COPIER WON'T WORK, DO I HAVE THE RIGHT DRUM AND IS THERE...
The AL1000 drum unit is the same as the AL1641 drum.
I do not recognize the MS1DR as a sharp part number.
You can reset the drum indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
This should make the copier operational again if all you have is the drum light.
Dec 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp al-1631 drum sign
This simply, You it is necessary to extract the drum from device and sprinkle the scraper , toner. Afterwards tested rotate the drum for anything numbered six manual and when squeak will disappear the insert it in device.
Sep 16, 2009 | Office Equipment & Supplies
Copier
Is the new one a compatible or a sharpe original if compat fit a new original as this maybe the cause if an original check and clean all the contacts or you just might simply have a faulty drum unit.
Thanks J
Oct 03, 2007 | Sharp AL-1651CS All-In-One Laser Printer
142 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
