Question about Spinmaster Air Hogs Yellow Jackal R/C Helicopter
Air hogs jackal main top rotor does not spin at all.
Hey. I bet you asked to experts for this-well you get me. Ok so i think you either need a new one or it is gummed up with hair. Have a look online for spare parts or take it to your supplier
Posted on Jun 12, 2011
The tail rotor wont spin
It appears that the tail rotor holds the horizontal stability when going backwards. i.e. only works when command is backward.
If the tail rotor does not spin then try lubricating the shaft with some talcum powder. To test whether it working blow down on to the rotor and it should spin rapidly. The talcum powder worked for me.
May 05, 2011 | Spinmaster Air Hogs Yellow Jackal R/C...
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
Why won't my havoc heli's main rotor spin
i would try to look for hair stuck in the main rotor
Mar 09, 2010 | Air Hogs Havoc Heli Helicopters
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Hi, the main rotor of my havoc helicopter is spinning in an unbalanced way and causing a high level of vibration making flight impossible
Look on the underside of the rotor. You may be missing one of the small metal weights that balance the rotors.
Jan 08, 2010 | Air Hogs Havoc Heli Helicopters
Air Hogs Micro Havoc Heli spins wildly
The same thing happened to me. It turned out that some hair and fibers got wrapped around the tail rotor axis. I pulled the tail roter off and cleaned it out. After I put it back together it worked fine. I hope this helps.
Dec 26, 2008 | Air Hogs Toys
Main rotor does not spin on brand new Air Hogs Havoc Stinger heli
After having the same problem I got through on the phone to spinmaster this morning (it only took about five minutes). They said the problem is likely that either the gears have slipped or the shaft has disconnected from the gears and motor. They said the problem cannot be fixed by the user and the solution is to get a warranty replacement.
After opening a warrant case and giving me a case number (important!), the customer service rep asked me to email a copy of my receipt along with a picture of the helicopter with the main rotor cut off (to show that we weren't using it any longer) to their warranty department along with the case number and a description of the problem. She said they would ship out a replacement within two to six weeks. Hopefully this works. Good luck.
Dec 19, 2008 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Spinmaster Air Hogs Yellow Jackal R/C Helicopter Logo
314 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Terry
Terry
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
