Question about Whirlpool LER4634J Electric Dryer
No hot air coming into dryer-- Where is the heating element located PLEASE???
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
Can't find model11066922500
Hello;
My name is Peter. I am a retired field service appliance technician.
Your heating element is difficult to get at.
25438420-j5jtgwve0qxm0uckbdimcx40-4-0.jpg Unplug the dryer before installing this heating element. Remove the bottom front service panel to access and replace the heating element.
This heating element is rated at 5500 watts.
This Dryer Heating Element part #3387747
Cost: $59.00
It is located in side the housing.
You may just be plugged up with lint in your hot air distribution manifold.
Or have a bad high temperature limit switch located on the back on your hot air exhaust manifold.
25438420-j5jtgwve0qxm0uckbdimcx40-4-5.jpg Tell me what your problem is.
Feb 16, 2015 | Kenmore Dryers
How can i hot wire my dryer so it will get hot
I would not recommend "hot wiring" your heating element, you could cause a fire. There are safety components in the dryer that will keep the element from coming on or getting too hot. First thing I would check is to make sure that your exhaust line is clear, one of the first killers to proper heating is lack of air flow. If the exhaust line is clear than I would look at the thermostats for your dryer. Depending on the model there could be anywhere from two to four different thermostats and frequently there is also a thermal link that if it goes bad the heat will not come on. Hope this helps and please do not try to hot wire your heating element!
Mar 18, 2014 | Kenmore 63942 Dryer
Changing heat element on a ge 223 dryer
open the door there are twp screws there remove them take top off then the front remove belt and drum the element is in the back
Apr 21, 2010 | GE DVLR223 Dryers
Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Nov 11, 2009 | Kenmore Dryers
I have an electric dryer it is not heating up blows cool air not hot air
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. If this is not the nodel you have, please get me your model # and I can give you the proper instruction for your model.
I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 14, 2009 | Kenmore 63942 Dryer
No heat
this happen a lot on this dryers locate the heat sensor on the back of the dryer is located near the exit air duct it looks like a white piece of plastic with 2 wires on it get a volt meter and test it for conductivity this sensor control the heater element and if the air coming out from the duct is to hot this sensor burns so make sure your duct line is clear and don't put just few clothes on it because your dryer will get too hot again and it will burn this sensor again go to a repair shop for dryers and get one they only cost like 5 dls bye a second one to have it ready if happen again and if this sensor is good then check your heater element for conductivity heater element is only like 20 dls
Mar 27, 2009 | Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
Dryer does not get hot
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
