Hi I have a starway split system air conditioner and the remote is no longer working - I have purchased an Ultra Univrsal Remote and need to know the code to make it compatible with the starway air conditioner - please help - thanks cindy
  • 2,133 Answers
In my experience, the related remote is better than universal remote, as it's not designed for particular unit, but for multi.
Anyhow, take universal remote, power on your a/c.In front of your a/c, press setting and then < or > continuously. In your remote the number will go up or down as 999.........998.997......... or 1101...102........103...104. like that. Stop, when you get response by beep sounds.That is code for your a/c to operate. Helpful?
Posted on Dec 30, 2010
  • 1 more comment
  • joy776 Feb 15, 2011
    I have the sae problem - again with a Starway AC. The Universal remote went up to 99, but none of the numbers got a response. Could it be incompatible?
  • sharonwall50 Jul 12, 2011
    did you solve the problem with your remote
  • Gustavo Fischer Aug 22, 2013
    Hi, I would like to buy a Starway remote. Does anybody would like to sell a Starway remote to me?
I have a different problem subscription but perhaps it could be the same source...In my apartment are two Starway airconditions. I have two remote controls. Both are working at the one in the living room. Before also both were working at the one in the bedroom.Now the bedroom-aircondition suddenly doesn't switches on or even do a beep on any of these remote controls... I've had this problem once before (some weeks ago) and after a while luckily it was able to be switched on again - like magic. Now it's not working since a day. The red power LED was on and the green 'running' LED was flashing. I already switched off the power for a while (with the fuse for the whole room). The red power led was off during this time. It comes up again the moment I switched the power back on, but that's it. Nothing more is working. It cannot be related to the remotes, because both are working normally at the living room.A small clue - the fan outside is a little bended and scratches a very little at the metal case. So the resistance for the motor could be a little higher to turn the fan. But this is since I'm in this apartment (3month) and seemed to be like this a long time ago, too...Does somebody has any ideas to check? I need it urgently back in service, because I use it for heating and it's getting really cold now in the bedroom :-/
I don't know if this could also be the problem from the person that started this thread. Perhaps your old remote control was working (like mine) and just the aircondition doesn't work with any remote any more. So your universal remote could hit the right numbers but nothing will happen ...
Anybody else had a problem like this?
Posted on Nov 04, 2011
Hi.... My Air conditioning remote control AR-DL1 doesn't seem to be working.It's been working on and off for a while,but now ....Nothing at all ( I changed the batteries also ) .Since I don't know if it's...
Remove batteries and keep for 5 minutes. And also remove DC wire plugged in display sensor in your indoor unit. Now, plug again DC wire in same position and also put batteries in remote. Power on and try now. In many units, this type of resetting would help. If still problem, check remote thr' camera mobile by pressing any button in remote. If ultra light flashes, remote is o.k.You have to repair/replace PCB only. If no ultra light, replace remote.Thanks.
Feb 01, 2011 | Heating & Cooling
Split system air coditioners (3 off) LG LST243C-2, remote controls work intermittently or not at all after batt change. Reset does not help. Are they able to be rejuvenated (?) or is replacement only...
There is transmission problem. either with remote or in PCB. Check with mobile camera by pressing any button in your remote. If ultra light flashed in your remote, it's o.k. Then you have to repair/replace PCB only.
Jan 20, 2011 | Heating & Cooling
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
LG remote problem
Most probably if the remote works on the other units then the receiver on your problem unit is busted. You have to call an authorized service repair shopr to replace the board.
I hope it helps.
Jun 13, 2009 | LG LSC121PMA Split System Air Conditioner
Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
May 08, 2009 | Sanyo 18KS52 Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
A/c remote working but system wont respond
Heya Allhart?
How did you check the remote? Did you check the remote via viewing it on a LCD screen? If the remote is working than you need a new receiver PCB for your air con and would contact Sanyo to see if it is under warranty or for them to get someone out to veiw.
Hope this helps
Jan 01, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
1,057 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
