Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore 25351694100 compressor not operating
The problem I have been having is the compressor would start by making some louder than normal sounds and then click off. The compressor would be hot to the touch and the compressor fan is running. Eventually the refer would warm up and begin to defrost. I emptied the fridge/freezer and unplugged. The next day I would plug back in and it would run fine for a month or so and the problem would repeat. Now however the compressor is not even coming on even though the fan is running. The compresssor is at room temp with no sounds or vibrations. Is there a fuse or breaker for the compressor? Is there a wiring diagram that I can see where power for the compressor is originating? Thanks
  • fixathome Jul 07, 2008
    Can the overload protector be reset? Does it just open during overcurrent or high temp? Can you Ohm out the relay or overload protector? Should the relay out of circuit show zero resistance or will it have to be engaged by the control board? Thanks
  • fixathome Jul 09, 2008
    Ok Here's my progress so far.... The starter cap is good (15.5uF). On startup the compressor is drawing 9.6A before cutoff. The compressor is really trying to start but all I get is the loud hum then it shuts off. The starter realy is warm to the touch. I hoping it's just the starter relay PN 218721119.
  • 828 Answers
There may be power to the compressor. You can check it with a volt meter by checking the two electrical leads at their connections.
across the line you should read 120 Volts. This indicated power is there to the compressor and your overload protector may be open. The overload "protector" and "relay" can be ordered from Sears by your model and serial number along with the names of the parts for the compressor.
Posted on Jul 07, 2008
  • James Helmer
    James Helmer Jul 08, 2008
    Answer to your first question. These overloads are designed to be fully automatically reset. There is no manual reset for them. They open under both conditions. High current and high temperature.
    Most relays on these smaller compressors are current type relays. When the compressor is energized and a current is drawn through the relay it engages the start winding in the compressor motor. When the compressor comes up to speed the current drops off and the relay start contacts drop out allowing the compressor to continue to run.
    The cost of replacement relays and overload protectors are minimal compared to the cost of having someone make a service call. Replace them.
    If you read out voltage across the line, something is open. Could also be the compressor motor itself.
Why refrigerator kenmore model 25351694100 buzzing sound when it dispenses water
Has it always done this since new? Ours has made a sound like this from day one....
Jun 09, 2014 | managemylife.com Computers & Internet
Kenmore elite french door refrigerator and freezer not cooling
Check the compressor start device. The fans will be running and the compressor fan will be running but the compressor is problaly not running. If it is then it could be the compressor itself that is not oumping.
Mar 25, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
Kenmore 90 Series Dryer started to operate very loudly. The noise sounds like it normally does while drying, just much, much louder than usual.
I would think the belts are getting bad need to be checked anyway, also while your checking the belts check the tenision pulley for the belts make sure it has not fallen off, also, make sure dryer is LEVEL, hope this helps let me know please thks larry
Feb 27, 2010 | Kenmore Dryers
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My Kenmore upright freezer is about 6 years and has recently begun running noisier than before. Not a rattle, and not a rough sound, normal operation sound but just louder. Should I wait until it goes out,...
Check the evaporator fan inside the unit
Check the condenser fan (if equipped) under the unit
Check the compressor mounts - they are rubber and could be wearing causing the compressor to be touching something under the unit, making the noise.
Check for any loose parts like screws, hinge screws, sheet metal etc.
Dec 18, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Noise & Clicking at regular intervals on working Kenmore 72214
yea that is the compressor relay, you will start to notice your food to thaw out and get bad. try to unplug for about an hour. if then it still does that call www.whirlpoolpartssurplus.com and get a relay kit.
May 06, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
Microwave makes strange sound when turned on
The fan motor either needs maintenance including lub or it need to be replaced.
Jan 01, 2009 | Kenmore Microwave Ovens
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
498 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
Fred Sops
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
