Question about kawasaki Garden
Can I use clutch assembly # 13081-2224 to replace the original clutch assembly # 13081-2218 for my Kawasaki TD040J-AC63 brush cutter?
  • 25 Answers
SOURCE: the starter housing assembly of my ryobi brush cutter is damaged
If your somewhat mechanically inclined, you should be able to. I would need your model # to quote you a price for this part. We are a warranty service center for Ryobi, Ridgid, milwaukee, Campbell hausfeld, etc. Email your model # to desertairrepair@aol.com. I'll send you the schematic for your trimmer.
Posted on Feb 12, 2010
voodoomox
  • 1689 Answers
SOURCE: putting clutch assembly back together
ge the manual here so you will be able to put the assy back properly
http://www.myxmanuals.com/modules.php?name=Content&pa=showpage&pid=9
Posted on Apr 13, 2010
brector3
  • 1625 Answers
SOURCE: cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Posted on Jun 04, 2010
rycgl
  • 1545 Answers
SOURCE: How to remove the clutch
Remove the clutch housing...should be a small Torx head screw in the neck of the housing, screwed into the threaded end of the crankshaft. Once housing is off, rap on the solid inside ears of the clutch with a small hammer and flat-head chisel..counterclockwise. If stubborn,don't beat it to death. Use penetrating oil on it and try again later. It will come off.
Please vote on this solution.
Posted on Aug 31, 2010
DysonInfo
  • 107 Answers
SOURCE: dyson dc04 wont pick up,motor working,replaced
You need to go through a process of elimination. You are better doing that here: Dyson advice forums
Posted on Nov 30, 2010
How many turns on the mixture screw on a TK carb fitted to a td24 kawasaki brush cutter
initially all the way in then 1 1/2 turns out
adjust out or in to get smooth idle
Jan 22, 2017 | kawasaki Motorcycles
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc07
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 09, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
1988 Kawasaki VN1500 how to rebuild the clutch
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
VN1500 Clutch Problems Kawasaki Vulcan Forum Vulcan Forums
how to change clutch replacement by Dmitry
http://xn--80azbq.xn--p1ai/failo/Kawasaki_VN1500__87-_99_Service_Manual.pdf
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 11, 2018 | kawasaki VN 1500 Vulcan Classic...
1991 Kawasaki KX 125 clutch hard to disengage
Hi, Chris and the usual suspects are:
1. Clutch cable bent, kinked, pinched, rusted or needs lubrication.
2. Hydraulic clutch hose collapsed or pinched.
3. Improper clutch adjustment.
4. Clutch plates rusted.
5. Pressure plate or springs to heavy for service.
6. Damaged clutch shell.
7. Damaged, bent, or stuck push rod assembly.
8. Faulty worm gear mechanism.
KX125 Clutch doesn disengage
clutch wont disengage
Kawasaki KX125 Service Manual
1991 Kawasaki KX125 Owner Manual
Feb 12, 2014 | kawasaki KX 125 Motorcycles
Error code c410 on cs-2218
If a C410 Error occurs, replace the DP-410 Main PCB Assembly, Ground Wire and Screw.
The PCBs part number is 303HL01018.
Apr 01, 2013 | Copystar Cs-2218/cs-2221/cs-2225 Developer...
Kawasaki brush cutter th34, clutch removal. There are two hex headed bolts holding the clutch mechanism into place. I was able to loosen both bolts but then after maybe 2 or 3 anticlockwise turns both...
Please use lots of care if you use the Internet to hunt for your repair manual!
These clowns CLAIM to have one for your TH34 but you MUST REGISTER to get it...suddenly MALWAREBYTES PRO started flashing 'alerts' about attempts to install a VIRUS on my system ~ NOT good!
The CLAIM to have MANY PAGES of desirable manuals to download from Harley s to whatever... Do NOT even TRY to download any:
monlongboardelectrique.com
AKA
monlongboardelectrique.com =
107.154.168.213 and 107.154.234.213
Dec 25, 2017 | kawasaki Garden
The starter housing assembly of my ryobi brush cutter is damaged
Feb 02, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I replaced the clutch in the dyson dc14. it isnt making that terrible noise anymore....thank god!! but the roller brush is not moving when the vacuum is in use. whats wrong?
The "horrible noise" you were hearing before wasn't the clutch! It was the roller brush. If the brush is not turning, all you are doing is burning out your new clutch. Reasons for the brush not turning: there is hair, carpet fiber or other matter wrapped around the brush that needs to be removed. Remove the roller brush, inspect it, and remove anything that could interfer with it's functioning. Reinstall and give it a test.
But in my experience, the brush needs to be replaced. Remove the brush and look for cracks in the plastic, If you see any, it needs replacing. eBay, via a distributor from England, is your best bet as far replacing the brush. Be careful of non-original brushes as they will break easily and are not of the same quality as the originals. Try searching for "DC14 brushroll" and then go down to the International Sellers at the bottom of the page.
Do not continue using the vac until you have solved the problem. You will only have to replace the clutch again.
Sep 22, 2009 | Dyson DC14 All floors Bagless Upright...
Clutch rattle
no there is not a kit available. I have tried it myself before and used other spec material for the damper in the clutch and made the rivets myself. Worked great but is very timely. I'd actually recommend buying a new basket. The side pedals on the original basket often get grooves from the clutch plates wearing on them which can cause clutch chatter too.
Dec 05, 2008 | 1975 kawasaki Z1B
Garden Logo
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
