Question about Black & Decker Black Decker 714" Circular Saw
Model : Black and Decker 7308 Type 7, 7 1/4 in circular saw when I press the switch, the blade sometimes work normal, sometimes doesn't move, sometimes move for few seconds, then stop
    Problem Solver:
  • 16 Answers
Go online and replace switch.
First tho check cord for problem
Posted on Dec 30, 2010
Is there a source for a blade guard for a Black & Decker 7308?
Dear Mr. Dunlap,
It appears that new replacement blade guards for the Black & Decker Model 7308 are no longer available. There are examples of used 7308 saws listed on eBay in the $12-$60 price range, although these prices do not include shipping costs, which are often two times the cost of the tool itself. You could purchase one of these saws, disassemble them and put the parts onto your existing saw, but unless the saw that you own has some emotional value it would cost the same or possibly even less to simply replace your saw with a new one.
Sincerely,
E. Bishop
Sep 25, 2014 | Saws
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
I need a switch for my black & decker 7 1/4 worm drive saw model 7395 type 1
That tool was discontinued in 1980 and parts are obsolete. You may be able to use a Skil 77 worm drive switch as many of the circular saw switches were configured the same. The switches are usually marked with a 1 and 2 on the back so make sure the wires are put on correctly as some will have the 1 on one side (top and bottom terminals) while others are on the top or bottom (next to each other).
Aug 05, 2012 | Black & Decker 7 - 1/4" Heavy Duty...
Need on/off switch for .Black + Decker circular saw 7308-07 please
Go to www.ereplacementparts.com and search for your saw in the Search by Model Number box. Use 7308, I think the 07 is the type. Select your tool and you'll get a good breakdown and be able to select any parts you need.
Apr 30, 2012 | Black & Decker Saws
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
Jan 12, 2012 | Black & Decker Saws
How to change the blade
first look for small button in the opositive side of blade, smash on it, move the blade till stops and then remove nut......
Jun 21, 2011 | Black & Decker 7 - 1/4" Heavy Duty...
The blade on my saw also moves about an 1/8" back and forth. I believe the the shaft has end play as the blade is tight on the shaft. Above is is stated to use a fiber type washer to fill the gap! ...
the washer would go on the outside of the blade facing the screw and then the screw would tighten the washer to the blade which would stop the 1/8" play amount if the saw is leaving marks what type of blade are you using a finish blade would have alot more teeth then a frameing blade how teeth does that blade have if you have any further questions message me back thanks Rick
Feb 25, 2011 | Black & Decker CS1012 7-1/4" 12 Amp...
B&D Corded Circular Saw - Arbor Does Not Move
This model is not equipped with a clutch so its possible that the gears are stripped, shaft broken. If the blade moves freely then this is probably the case. If blade does not move freely, check for any foreign objects between blade and blade housing. I hope this has helped if you have any further questions don't hesitate to ask. Please rate on the helpfulness of the answer. Good Luck and have a great weekend.
Apr 04, 2010 | Black & Decker CS1012 7-1/4" 12 Amp...
My black and decker, circular saw, blade moves side to side about an eigth of an inch. The bushing on the shaft appears short allowing some movement. Does any one know a fix for this?
Some things like this we have to improvise. Possibly a filler washer can be used. It is not clear if the shaft end play is what you have, or the blade clamping washers allow the movement. If it is the blade clamping, possibly there is a burr on the washer that prevents the proper mating of the clamping washers.
If it is shaft end play, then try to use a fiber type washer to fill the gap.
Feb 10, 2010 | Black & Decker CS1012 7-1/4" 12 Amp...
I have tried numerous times to undo a nut on my Black and Decker circular saw without success. which way do I turn the nut to undo it and take the circular saw blade?
Am I correct that this is a hand-held saw? Want to make sure of the terminology.
If so, the bolt holding the blade has right hand threads -- meaning it loosens by turning counter-clockwise.
Is there a blade lock? Are you using it?
Apr 30, 2009 | Saws
Black & Decker Black  Decker 714" Circular Saw Logo
1,026 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
