Question about Refrigerators
Frigidaire Frost=Proof Is Icing
I have a frigidaire Frost Proof top freezer refrigerator. The freezer is icing up on the back wall and I am not getting cool air in the bottom part. I have used the hair dryer to defrost and then we seem to work OK for a few hours. The fan in the freezer is working.
Model is FPCI21TFW1 s/n LA02406477. Tried to locate a manual online but I haven't had any luck.
Any help would be appreciated.
  • Anonymous Apr 05, 2009
    Freezer isn't cool enough. Fan in the freezer is working. Ice build up in the refrigerator. Fan next to the compressor isn't working when plugged in. Suggestions?
  • 828 Answers
There is a defrost timer located in the refrigerator compartment in the area of the controls. It will be covered by a plastic panel but there will be a hole in the plastic through which you can access the clutch head screw to advance it into defrost. Turn the screw clockwise very SLOWLY until you hear one audible click. this will put the system into the defrost mode. Defrost should happen in 18-22 minutes . after the 18-22 minutes the system should automatically return to cooling. If it does not restart after 25 minutes turn the screw a little farther to the second click. If you had to turn the screw the second time to restart the cooling replace the timer.
If the system restarts automatically but does not defrost your problem is an open defrost heater or defrost thermostat. These are located behind the back wall inside the freezer section.
Posted on Jul 07, 2008
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Condensation building up under crizper drawers icing up somewhat and overflowing out onto floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
oldtech2332_6.jpg-->-->
Aug 16, 2011 | Frigidaire FRT17B3A Top Freezer...
Frigidaire White 16.5 cu. ft. Top Freezer Refrigerator (FRT17HB3)- The freezer works, the refridge portion is warm, it started last week ans seemed intermitten, we turned the cooling higher and it was fine...
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Apr 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer cool but not freezing
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models they don't have the timer but an electronic device which replaces the timer.
Jun 30, 2009 | Frigidaire FRT21S6A Top Freezer...
Model FCD-123 Frigidaire malfunction
2 possible issues .evaporator fan motor is not working.you should be able to hear it in freezer.auto defrost is not working and vents are clogged with ice.look for ice/frost buildup on freezer wall///floor
Jun 25, 2009 | Refrigerators
HOW TO BYPASS
If the refrigerator is not icing up it could be the defrost thermostat making the defrost cycle initiate every time the defrost timer makes defrost available. I do not recommend by-passing the defrost cycle, have the switch checked and replaced if needed.
May 26, 2009 | Frigidaire Freezers
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Freezer
Check the back wall of your freezer section to see if it is icing up.  If so, you have an automatic defrost problem.  One or more of your defrost components (timer, defrost heater or bi-metal) has failed.  If there is little or no frost on the back wall, you could have a compressor related issue.  This is often indicative of Frigidaire refrigerators.  If the unit is less than five years old, the compressor is still covered under their warranty.  If it is the compressor and it is more than five years old, start shopping.
Oct 25, 2007 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
364 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
