Question about Gateway HD1900 19" Monitor
Gateway HD1900 model #LP1925 Monitor Powers on Normally then shuts off after 2 secs normal operation. Power indicator stays blue. Turning the monitor off then back on produces the Same results. Any clue what the common problem is for this.. I have seen a few forums saying that this is a fault in the design "capacitors are to cheap of a grade". When i look at the power inverter all the caps look to be in good condition. however I feel less then confident in my ability to find a bad cap. Please help Sincerly Darrell Crain
  • 2 more comments
  • hmdarrell450 Dec 30, 2010
    Were do i find the actual Part number for this board there is plenty of random numbers lol to bad im a novice.
  • hmdarrell450 Dec 31, 2010
    ok I have used every number on the board with no results so here is the photo.. sorry and thanks
    http://i1084.photobucket.com/albums/j406...
    H791491400700R
    ""Barcode "
    RZ51 0908
    Tried to enlarge the label but still fussy. The above is what is on the label
    can u type out the actual part number im not definite here and indeed novice... ill be calling Mundo corp for the part 888 278 7500 case u ever need there direct number
  • 4,889 Answers
Not all backlight inverter problems are caused by faulty capacitors. You must have noticed that there are a large number of solid state electronics on the board that could well be the source of the problem. Either way since the backlight inverter board is very inexpensive(costs about 20$) its recommended that you replace it. If you can get me the part number I can find you a replacement.
Posted on Dec 30, 2010
  • 2 more comments
  • eagle338
    eagle338 Dec 30, 2010
    You can find it printed on the board itself. You can also get me a high res pic of the board and let me find it for you. Please upload the image to imageshack.us and get me the link.
  • eagle338
    eagle338 Dec 31, 2010
    What does the label on the extreme left say? The yellow colored one. Also please get me a close up of the extreme left section.
  • eagle338
    That is the part number but I cannot locate a store that stocks the part. Perhaps its best to contact gateway for a replacement board?
    http://support.gateway.com/support/conta...
    Via E-mail
  • eagle338
    RZ510908is the part number. Also quote the make and model of your monitor when you call them.
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
It powers on and then off in sec.
I think your OS or some hardware are bad. Post more info.
Oct 02, 2014 | Gateway Fpd2185w 21" Widescreen Lcd...
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
Looking for the gateway hd1900 lp1925 drivers, any ideas?
No ideas here, but if you find/found them please link. Thanks!
Oct 09, 2010 | Gateway HD1900 19" Monitor
What is the most likely cause of the problem of a gateway HD1900 monitor fine works for 5 minutes when powered on then goes dark but imagine can be seen in background
The back lighting fails - the CCFL tubes lose their power most likely because of a bad contact.Open the case of the monitor and press all wires firmly in their connectors.
Sep 04, 2010 | Gateway HD1900 19" Monitor
FPD2275w monitor monitor powers on but shuts off after 1 sec shows a picture perfect before it goes black all buttons light up and stay lit sounds like they r working
This model will likely have 2 or 3 bad capacitors in the power supply. You can see the tops bulging. They are 1000Uf @ 10 volts.
Monitor Mike
Aug 20, 2010 | Gateway FPD2275W LCD Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
The power indicator always comes on whenturning power off and on from power strip. Monitor screen is blank
This is normal behavior. I assume that once you turn on your power strip, then you press the power button on your PC, it powers up normally? That's ok.
Mar 04, 2010 | Gateway GT5228 PC Desktop
Gateway HD1900 19" Monitor Logo
2,318 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
