Question about Tivoli Kloss Model One AM/FM Radio
How do you open the case of a Tivoli Model One Radio?
3 Suggested Answers
  • 155 Answers
SOURCE: My Tivoli Pal radio casing has a sticky feel on
Rubberized coatings or cases when exposed to handcremes.. suntan lotions.. or bug repellents will breakdown and get become sticky.. certain environmental situations can also cause the rubber either to breakdown and either get sticky.. or get hard and brittle..
Sounds like the radio has been handled or exposed to some type of petroleum based product as I mentioned in the first line... even sitting near certain uncapped distillates can result in this problem.
There is a product in the boating world called Speed Clean Vinyl and Rubber Cleaner that may solve your problem.. if succesful.. remember to apply some type of protectant afterwards.. most Boat dealers or marine and fishermen supply stores should carry this product.
The only other solution is to remove as much of the sticky coating with an ammonia based product and recover.
Good Luck
Posted on Feb 23, 2011
Just cleaned mine this morning because it was so ridiculously sticky and dirty with great success with nail polish remover and cotton pads. Read this solution posted elsewhere but was worried about ruining the finish, and there are warnings on the bottle about not using it on plastics......but tried a bit on the back. Went very well and with a load of pads and alot of scrubbing, it came completely clean! No sticky residue left, no discolouration. Looks brand new!
Posted on Jul 19, 2012
Transformer to old PAL Tivoli been eaten by rats. Where to find another for this old model
Try radio shack in States, Maplin in the UKand other similar retailers elsewhere. Also, if you can identify it try ebay, they carry a lot of these parts
May 30, 2015 | Tivoli (PAL) AM/FM Radio
Disassembly of the tivoli table top radio
After removing the 6 screw, gently slide the front panel out of the box. Now disconnect the little 2-way connector with a black and white wires: it should be the more tight cable between the front cover you have just removed and the rear panel.
Now slip-on your fingers in the box and push the rear panel up to slide it off the box, so that you can turn gently the front panel, pass it through the box and get the electronic completely apart from the wooden case.
Mar 16, 2012 | Tivoli Kloss Model One AM/FM Radio
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
Hello, my Tivoli radio was brought to Australia after an overseas trip to America. After adapting the plug I connected it to the power point. As I now know- the different (higher) voltage in Australia...
Hopefully this is just something simple like a blown fuse but here is a link to some recommendations on how to repair the radios
https://www.techwalla.com/articles/how-to-repair-a-tivoli-radio
Jan 06, 2018 | Tivoli Kloss Model One AM/FM Radio
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
Jul 30, 2010 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Model One Radio Humming only, no reception
The fuse would cause a total absence of power. Your problem is likely a blown filter capacitor in the power supply. Unless you have electrical/electronic skills, the radio will require professional repair.
Oct 10, 2009 | Tivoli Kloss Model One AM/FM Radio
Tivoli Model one radio - volume control does not go to quiet. I like to listen at night but volume does not lessen past a certain point which is too loud.
I noticed the same problem after I had moved. Hadn't had it before. The solution was easy in my case. (It took some time to accidentally figure it out though). I flipped the power cable around 180 degrees / upside down and re-connected. After this the volume worked as before. This was the model with European power plug.
Mar 01, 2009 | Tivoli Kloss Model One AM/FM Radio
Tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Dec 26, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Tivoli Radio "Model One" Volume Problem
TRY SPRAYING A LITTLE CONTACT CLEANER ON THE VOLUME CONTROLL
I EVEN USED RUBBING ALCOHOL.
Mar 23, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Kloss Model One AM/FM Radio Logo
502 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
