Question about Dryers
Dryer will turn but only with very small load
  • 2,509 Answers
The belt is probably slipping, with so little information it's hard to diagnose. Take off cover after FIRST DISCONNECTING MAINS, get someone to grip belt firmly while you turn drum slowly by hand. SLOWLY as you dont want to trap any fingers!!! If the belt stays where it is but the drum turns its not tight enough. Also examine the route of the belt through the pulleys on the motor. Come back with more info.
Posted on Dec 30, 2010
Bought new Samsung dryer and won't turn on - wired incorrectly on first attempt, did we short the dyer?
Hello
Just a hitch, but maybe the fuse is bust and needs to be replaced.
ilona
Aug 02, 2017 | Samsung Dryers
Kenmore dryer is not heating up. Any troubleshooting info?
It could be the element,or maybe your dryer vent is pluged. Pull your dryer out and check to see if it is full of lint.
Apr 21, 2013 | Kenmore Dryers
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 | Dryers
Maytag Dryer MDE 4916AYW: Drum doesn't spin, makes buzzing sound when drying avergae size load works fine if put in small load
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 15, 2010 | Maytag Dryers
The dryer drum will not turn.
Could be belt gone if the drum is quite easy to turn by hand. Or motor in @worst
Apr 01, 2010 | GE Profile Harmony DPGT750EC Electric...
Replaced motor dryer only handles small loads
Is the motor an original replacement and was the pulley installed properly? Is the belt in good condition? Was the belt tensioning device installed as previous? Were the drum bearings checked? Why did the previous motor fail? Answers to these questions may help correct the problem. Check to see what stops turning besides the drum when a too-heavy load is presented.
Nov 12, 2009 | Kenmore 62602 Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Ge dryer only dries small load
either your heating element or your limit switches are going out
Feb 04, 2009 | GE DHSR333EV Dryer
Tumble dryer fault
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through
replace both rollers or both felts if one is worn
Jul 01, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
