Question about Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power
After about 1 km on any power setting the scooter slows down on its own then surges up to power again. it gets a small back emf and this seems to help but is persistent some tiime down to 2 km/h checked the variable resistors and they seem ok only persistant thing is the reverse is always a bit slower than usual even when fresh. checked the main connections to the motor/controller and no heating of the connections. any clues thanks
  • kayedgecumbe Dec 30, 2010
    thanks it would seem more like brush gear so will check out from that angle
    as well i think the reverse resistor may be also need checking, thanks
    batteries are good as thee scooter always picks up after a few meters
    thanks for the info
    LOL just remembered i had the same symtoms years ago and it was the brushes then
  • 280 Answers
Based on your description of the symptoms, I would load test the batteries, check the throttle potentiometer, speed potentiometer , motor brushes and motor brake. I cannot determine your specific model based on the way the problem was posted, so it is difficult to give specific advice.
Weak or old batteries will give the performance you are describing. Fully charge the batteries and load test them to determine their strength. Batteries more than 1.5 years old are suspect. Without a load tester you can do a load test by connecting your digital voltmeter to the batteries and run the scooter under load (driving it with weight on it). If the voltage drops more than 1.5 volts from a starting voltage of between 24 and 27 volts the batteries are weak.
Generally speaking, you can do a resistance check of the potentiometers throughout the range using a digital voltmeter. The specification for the potentiometers is stamped on the case. If there are dead spots when you turn the potentiometer based on a drop at the voltmeter then your problem is with one or both of the potentiometers. I usually replace both since they are usually wired in series.
Worn or bad brushes, worn motor armature, accumulation of brush dust, or a dragging brake can also cause the symptoms you describe. Pull and inspect the motor brushes for wear or burning. Blow out the motor with compressed air with the brushes removed and inspect the brake for discoloration or dragging. Do a resistance check on the brake. It should read between 30 to 60 ohms. The motor coil should read between 0 to 1.6 ohms.
Hope this helps.
Posted on Dec 30, 2010
Mother's scooter keeps dying
How old is the battery they don't last forever and they are not cheap
Sep 28, 2015 | Pride Go-Go Elite Traveller 4-Wheel Travel...
I just replaced batteries and the scooter is really slow. Also a rubbing sound from the back but nothing is touching. Any ideas
If the battery is new and fully charged and you have this problem then something is binding in the power train. See if you can disengage the motor from the train to see if it speeds up. If it does so appreciably then that is definitely the problem. Do not use it like that because the slow operational speed of the motor will result in less back emf, & considerably more current consumption resulting in motor overheating, burnout!
If motor still runs slow when disconnected from power train, then something is wrong with the motor. Perhaps the bearings are all gunked up. If some of the windings are shorted out the motor will also run slow and is in need of replacement.
Aug 30, 2015 | Health & Beauty
My bruno regal 44 scooter seems to slow down after a few hundered meters, once I stop, its at full speed again, is the a safety feature?
You maybe experiencing a brake hanging up, causing drag on the motor. the brain box senses over current use and will automatically slow down. The motor brushes maybe worn down and have a build up of carbon powder, particularly on the bottom side of the motor, causing this problem, remove brushes and blow out with compressed air, no Sprays please this can cause more harm than good. Note take out all brushes before blow it out with air. Check brushes springs are not discolored. http://www.strege.com/BlueDoc
Jul 29, 2015 | Health & Beauty
Invacare meteor, keeps slowing down, then speeds up again, can you help.
usual cause of this is the throttle (wig-wag ) controll potentiometer has worn out.to test put the scooter against a wall and get a freind to lift up the rear of the scooter and put 2 large blocks of wood underneath it so the back wheels can rotate
carefully advance the throttle 1/2 way then with wheels turning.keep in same position and gently move the throttle lever up and down .if there is a lot of play and the speed varies drasticaly then pot replacement reqd .you can get a dealer to order the correct one or get one off the internett but when fittinf if thr pot is not set to exact center with multimeter scooter will not move and produce off center error code
Sep 27, 2014 | Invacare Health & Beauty
Kymco **** 125 (1998) Engine lost power then cut out, now won't start
Is this a gasoline powered motorcycle/scooter? If so and if you got off in dirt, the carburator may have dirt in it. Drain the gasoline, clean the jets in the carburator and try again. If its electric, sorry, can't help!
Aug 15, 2012 | Cars & Trucks
I have a sterling diplomat 306 id,
Look at the right hand back corner of the bootlid recess, there is a very small steel spike sticking up which is a switch. Sometimes if the scooter goes over a sharf bump, the lid jumps slightly and the switch lifts momentary and puts the brake on. It thinks the lid has been lifted and goes into charging mode.
Switching the power on and off resets the system until the next sharp bump.
The switch is ajustable, or the bootlid needs to be pushed down harder before locking it.
I had this happen on my Diplomat 408i.
Hope this helps.
Regards,
Paul
Jun 01, 2012 | Health & Beauty
Invacare auriga looses power
Hi. Most probably its the throttle pot ( Wig Wag ) thats causing the problem. I am an Invacare service agent and I have changed these many times for this very reason.Also check motor brushes are not worn down or jaming. Good luck. Neil.
Mar 21, 2010 | Health & Beauty
Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power Logo
234 people viewed this question
Top Power Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Power Health Health and Beauty Expert? Answer questions, earn points and help others
