Question about Refrigerators
Whirlpool GD5SHAXNS00- Light on refrigerator side will not work nor will control temperature light up. Light on Freezer side works and refrigerator cools. Tried new bulb, no success.
  • 27 Answers
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Posted on Feb 02, 2008
  • 3 Answers
SOURCE: Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Posted on Mar 17, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
tborn6
  • 700 Answers
SOURCE: Whirlpool side by side refrigerator not cooling
yes do the check for the baffle. set the controoler for the thermostat to off and the freezer to the coldest setting while have the doors open. take the cover off the baffle and observe if its closed . should close in 10 seconds, also the compressor should be on, as should the evaporator fan and the condenser fan. turn the controls the oposite and the baffle should open. Also make sure that you have seperation of product so that you haev adequate air flow in frig.
Posted on Feb 07, 2009
  • 3600 Answers
SOURCE: whirlpool 6 sense model WSC5513- A+ X side by
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Posted on Aug 20, 2009
Replaced light bulb, still not working, also
the control panel need to be replace :( not so cheap but it happen to me also.
Dec 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bulb does not light on refrig side. When it happened it popped out the two control knobs. Reset control knobs and replaced bulb but the bulb will not light. After resetting the knobs the refrigerator...
i would alssume(knowing about this refrig) that the leectronic control board hasgone bad. the board is located behind the unit next to the compressor, inside a white housing, if you rmeove this board yull probably see a "burn" on one or more ofthe resistors, this is what controls the lighting in refrig sect, not affecting the cooling but only lights
Mar 04, 2009 | Refrigerators
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side refigerrator light stopped working even
1 does the light on the control come on when you open the door ?
2 does the freezer light work?
3 if yes to both then...the control board (light control) is faulty
Dec 16, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool gold refrigerator
YOUR FRIDGE DAMPER CONTROL COULD BE FAULTY IS TO THE TOP LEFT BACK OF THE FRIDGE COMPARTMENT.GOOD LUCK.MOHAMED
Sep 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Dec 31, 2007 | Whirlpool GS6SHEXNL Side by Side...
Open Questions:
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
