Question about American Dynamics ADMNPLASMA42 42 in. EDTV-Ready Plasma Television
Trying to hookup a toshiba dvd player to rca jacks, what mode do i Need to be in on the TV to get it to play? I tried composite video and on the AIR and CATV channels 2-6 to see if that would work but no luck. Also i do not have a remote for the TV which makes this a little bit more difficult.
  • American Dyn... Master
  • 8,457 Answers
Try website like Remotes.com to buy an original remote.Than try remote input button like 1,2,3 should be in one of it inputs .This is a digital tv,will not work on channels.
Posted on Dec 30, 2010
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How do i connect my dvd rv32 to my sony tv?
It will depend on your TV's inputs. The included cable is a composite A/V cable. This will work. Match the RCA plugs on each device (yellow to video out on the DVD player, video in on the TV; white and red audio go similarly). Alternatively, you can get and use an S-video cable.
For a better picture if your TV has Component video, get a Component video cable (this has three RCA jacks colored red, green and blue on each end) and then use that. You can get a separate audio cable that only has the red/white RCA jacks (or use the composite video with the yellow video jacks dangling).
If your TV doesn't have Composite video inputs, you need a RF modulator (Composite to RF converter). These are available at many sites, including Radio Shack.
I hope this helps.
Sep 06, 2010 | Panasonic DVD-RV32 DVD Player
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Connecting protron dvd to dish TV
I hope you have at least 2 sets of RCA jacks for (1) the Dish receiver and (2) the DVD player. Run 2 sets of R/W/Y cables to the TV. Done. Or use S-video for a better picture instead of yellow.
If you only have one composite input on TV (possible) then either buy a 2-way or more switch for the composite signal (R=right sound W=left Y=composite or S-video instead of composite) or you can instead pass the signal through the DVD recorder on the RCAs but the DVD will be on whenever anything is on. I assume you do not have a Dish 111 with only RF output but the same could be done for just the wimpy RF, just different switch. So there will be 3 RCA cables from Dish to a recorder and 3 then to the TV. Since you do not have a recorder, then go back to the switch or find another TV input.
Ten years, hum, you may not have had composite/S-video inputs and would have to use RF only--you did not say what TV was.
-Ken
Jul 19, 2009 | Protron PD-800 DVD Player
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Connecting a panasonic dvd player to a 38 inch toshiba tv
Check the TV menu for S video to composite video mode setting if there is any.
Try switching this mode and if nothing then tell me whether u are using component video or composite video cables
Rifaa
Nov 17, 2008 | Panasonic Toshiba MW20F51
Hookup
very simple , just made sure dvd output hooked to the input of your tvs and same color ,jack to jack,you know, yellow to yellow,red to red ,white to white.But I suggest you use a s-video jack(all black). instead of the yellow composite ,or RCA jack,which give you a better picture,and if you have a the component jacks (red, blue , green)on both machine , that will give you the best picture, but remember , you still have to connect the red(right channel,+))and white(left channel,-)cable to have sound coming out from your tv.You will need a s-video cable or component cables for those option I suggested.
Nov 17, 2007 | Sony DVP-NS55P DVD Player
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
American Dynamics ADMNPLASMA42 42 in. EDTV-Ready Plasma Television Logo
Top American Dynamics Televison & Video Experts
Electro Med Services...
Are you an American Dynamics Televison and Video Expert? Answer questions, earn points and help others
