Question about Protron PLTV-26 26 in. HD-Ready LCD Television
27" LCD PROTRON FLAT SCREEN HAS SOUND BUT NO
  • Meg Kim Dec 30, 2010
    Thank you very much...this is very helpful and I will consider my ? answered once I try the steps you mentioned. I very much appreciate your resonse. HAPPY HAPPY NEW YEAR!!!!!
  • Protron Master
  • 6,993 Answers
It can' be a fuse problem but it could be a wire connection problem or video card problem.
But first, connect the TV to a DVD player using a RCA and observe if there would be sound.
In case you don't know; Yellow stands for video, Red stands for Audio and White also stands for Audio.
The wires will go from "OUT" of the DVD player to "AV IN" at the back of the TV.
If there is still no display after this, please let me know so that I may direct you further.
Good luck.
Posted on Dec 31, 2010
  • 10,515 Answers
Disconnect the TV for few minutes, say 10 minutes and then turn it ON.If the problem persists, then it would confirm an internal failure. It is neither a fuse nor wiring.There is no fuse in this TV. There is no wiring other than the connectors between various boards. Rarely, i have seen any issue with them. I could say, rare of rarest.
This is highly suggestive of ' bad inverter board '. You need to get this tested and replaced.
Initially, since the Protron PLTV-26 is an LCD type TV, a simple test is to shine a flashlight at an angle towards the screen. Do this in a darkened room. Aim towards the area where the volume level is usually shown. Press on the volume control Up/Down. If semblance of the level could be seen even darkly / faintly, then the problem with the Protron would be a backlighting issue. Backlight as the term implies, refers to the soft whitish glow provided by small tube like bulbs behind the screen. This then would almost always be a hardware fault, not a setting nor a configuration concern and would require that the PLTV-26 be opened up to effect repairs.
Options then are:
  • consider a DIY (do-it-yourself) repair if and only if comfortable working with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center (specially if still under some form of extended warranty) or a qualified professional.
If a DIY is being considered, possible suspects are:
  • CCF (cold cathode florescent) lamps (least likely);
  • controller (a possibility);
  • power supply particularly to the inverter (likely);
  • inverters (most likely).
Let me know,if needed further assistance.
Hope i helped you.
Thanks or using ' Fixya ' and have a nice day!!
Posted on Dec 30, 2010
  • taran_2005
    taran_2005 Dec 31, 2010
    Thanks for your response!!
    You are welcome. Do accept my solution, if it has been of any help.
    Thanks and Regards
    taran_2005
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
Proton pltv3250 no video but has sound
now you need to check the inverter pcb , sometimes there is bad capacitor , also make sure there 24 v coming from the power supply , if you have 24v caming from power pcb going to the inverter pcb most like open fuse on the inverter pcb
Feb 08, 2012 | Protron PLTV3250 32 in. LCD Television
I have a 20' protron flat screen tv. The picture come up briefly then goes out to black but the sound is fine.
The long board call the LCD inverter board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a long refurbish LCD inverter board for the replacement.
Sep 15, 2010 | Protron PLTV3250 32 in. LCD Television
No video but sound works fine
how old isw this set, get a flash light and point it at the screen look very carefully and see if you can see a pic if so then open it up you have a small pico fuse going to your lcd screen replace and that should fix it good luck
Sep 24, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Tv wont turn on
outlet power and fuse check them . don't forget that if you want to replce fuse , you have to replace with a fuse with same rating
Sep 15, 2009 | Protron PLTV3250 32 in. LCD Television
Protron PLTV26 - Only Audio but No Video
Hi jnks2005, We need to check your backlight, while tv is on and you have sound, take a flashlight and shine it on the screen, look very close and see if you can see a dark video image, If so you have a bad backlight inverter. You can try to unplug your tv for a couple of hours and let it reset but it is most likely the inverter. Let me know what you see and I can help you locate parts and instruct the replacement. Please rate this solution. lone99star
Jan 11, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
No video on my Protron PLTV 4250
check the video with a flashlight against the screen, if present the backlight inverter has failed.
Dec 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Proton 34 LCD tv
Looks like Power Supply fuse is gone. Replace with recommended rating and type of fuse and try again.
May 18, 2008 | Protron PLTV-37 37 in. LCD Television
Protron 37" HDMI not producing sound
Check the volume control on the DVR box. This is sometimes turned down. Good Luck
Mar 29, 2007 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
70 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
