I have had to reboot my system and my sound is not workin on my monitor as it says no devices but its built in to my monitor and thats workin
  • 34 Answers
Make sure the audio cable (maybe a USB cable) is connected.
Posted on Jul 08, 2008
Can't get the built in webcam to work on my computer
well....the Webcam has it's own connection to the PC, (typically a USB cable,) but the sound will come out of your speakers.....so if you have your speakers built into your monitor, then yes, there needs to be a 2nd cable from the monitor to the back of the PC. It should have a headphone jack at each end; there will be only one place on the monitor it will fit. On the back of the PC, there should be a small round pale-green connection to plug-in near the USB ports, (unless you have added your own separate sound card, then it should go there.)
If the video is not working, then check if it is plugged into the EXACT same USB port. You do not note what OS you're using....but usually I recommend a device be removed from the device manager, then rebooted several times before attempting to re-install it.
Aug 29, 2012 | Dell Inspiron 537 ST PC Desktop
I have a rebranded HP monitor that has a usb hub, camera, and card reader built in to the frame. TS-25W8HC is the rebranded model, the HP model is HP w2558hc. Problem: when I reboot computer system hangs...
This is normal for a lot of USB devices that draw current such as monotors, external hard drives, etc.
There is no cure except moving around USB cables, which MIGHT work.
Aug 15, 2009 | Computers & Internet
My built in camera is not workin my computer isnt detecting it at
first look on your cam for the model number and brand
example veo stingray 4420 drivers is what you would type in search,
next go to the websight for drivers or firmware
firmware is same as the cd program, this is a bigger download, under support webcam web pages
to install drivers, start settings control panel classic view should be on, then system on bottom hardware tab device manager, look for yellow mark next to cam, right click properties,update drivers then find cd location on hard drive
or have microsoft update search for it automatic
Jul 16, 2009 | Logitech Webcam
Sound device not working
Please try to check the sound device status if its working properly thru right click My Computer icon > Properties > Hardware tab > Device Manager > (double click) Sound, Video & Game Controller OR System Device > System Speaker. also, take note of the Troubleshoot tab. If still it doesn't work, I think you have to reinstall the sound driver (from its motherboard software CD if it's built-in type). best regards
May 12, 2009 | HP Computers & Internet
Built in speakers not working
Please try to check it from Control Panel > Sound, speech & audio devices > Sound and Audio Devices > Hardware tab > then select the Device Name then click Properties tab to verify its condition status or you opt to click Troubleshoot tab. regards
May 12, 2009 | Proview PX 780 Monitor
Acer monitor x193w, no sound.
May 11, 2009 | Acer X193WBD Monitor
Radeon HD 4650 = NO audio
uninstall the ati sound utility, these video cards have a built in high def audio chip for sound thru hdmi
Dec 07, 2008 | ATI Diamond Multimedia Stealth RADEON HD...
Phillips brilliance 180P, no sound from speakers
Go to the Start menu, open the Control Panel, look for the folder Sounds and Audio Devices and open it.
You should have some listing referring to your monitor. If not, look next at the folder System, then Hardware, then Device manager and check if there are any red 'X' next to Monitors or Sound, video an game controllers.
If you get really frustrated, you can delete your monitor from within the Device manager, leave the monitor turned on and reboot your PC. Windows should 'find' a 'new device' and install or ask for an installation CD (hope you have one) and give you a basic driver for video.
If none of this has helped, go to Philips support page and download and install the newest driver for that monitor.
Nov 25, 2008 | Philips Brilliance 180P (White) 18 in....
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Aug 26, 2008 | Compaq 17" Flat Screen CRT Monitor
I have two lg monitors on spreat dispaly adapters
You don't need a driver for the monitors, the native plug and play driver in XP usually works as well as any manufacturer supplied driver. What's happened is XP doesn't recognize the onboard display adapter. If this is a name brand system (you didn't mention what type it is) download the XP display driver from the manufacturer's web site. If it's a custom built system, there should be a motherboard CD that came with the system that has the display driver on it. When all else fails, download System Information for Windows from http://www.gtopala.com/ It will tell you what type of onboard display adapter the system has.
Oct 04, 2007 | LG L1717S-BN 17" LCD Monitor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
