Question about Emerson EWV601 S-VHS VCR
I put a tape in vcr, have to run errand, want to watch when I return....well, guess what, tape won't come out...what can I do without ruining my tape...it is one of those vcr tv combos
  • 4,234 Answers
With a little dis-assembly, the tape can be saved without any problem. The main issue is that this is really not a DIY repair. There are dangerous high voltages present inside the unit even when unplugged. I would not suggest you attempt to retrieve this tape. The repair cost for parts will be about $10 (belts). Check with a few local repair shops. They should be able to help with this at a reasonable price. A complete refurb of these types of units can usually be done for less than $100 total. I refurb these all the time.
Hope this helps,
Dan
Posted on Dec 30, 2010
VCR tape loads and put tape around drum but then kicks tape out without returning the tape to the cartridge or playing. tape is then hung up inside the mechanism.
Dirty heads or rollers usually cause that or the tracking path has worn and the rollers are out of alignment. I would try a tape head cleaner first. Video / music stores or electronic stores usually sell them. You get a special tape to insert and cleaning solution.
Dec 13, 2015 | Televison & Video
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
When i put in a tape, i get a squeeling sound, and the tape won't play.
The only way is to take the top off and watch what the tape is doing! You might even see some object inside which should not be there!
Jan 05, 2013 | Mitsubishi HS-U560 VHS VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
VCR ruining tapes by catching tape also shutting vcr off. What is cost of repairing?
i will say that $70 to start reviewing it.... you are better getting a new one, they run very cheap now.
Apr 28, 2010 | Philips Magnavox DVD/VCR Dual Player
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
Emerson EWV601 S-VHS VCR Logo
53 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
