Question about Gateway 510 X (10272197) PC Desktop
Push power button, no response at all even though the motherboard light shines when plug in power.
  • 374 Answers
Considering the the motherboard LED illuminates when you turn power on, the power supply is probably OK, however you cannot test it without a PC power supply tester. If the LED on your monitor does not change color from amber to green, you either have a defective power supply, motherboard or processor.
I'm sorry I cannot be of further help to you but this problem cannot be isolated without the proper test equipment. Accordingly, I highly reccommend that you consult and obtain the services a PC technician to determine the cause of this problem.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Posted on Dec 30, 2010
Desperate to get my Dead Desktop going again................
I always start with the power supply. Your power supply may not be producing all the power your motherboard is requesting, even though the light on the back is on. If you dont have a power supply tester, then you can try removing your power supply and trying a known working supply in it, making sure you have the right connectors on it for your motherboard..
I looked at a pic of your motherboard Asus A8n-vm and I dont see an orange (or any) button to push. Was that to reset your bios? If so, unplug the system from the wall, and carefully remove the battery from the motherboard. While it is out, push the power button on the front of the computer a few times. The computer wont start up, as you have it unplugged, its just to drain the motherboard of power to reset the bios. Then reinstall the battery, making sure it goes in the same as it came out (- is usually down and + is up). This should reset the bios info to the factory settings.But I still think it is a faulty power supply.
Feb 03, 2013 | HP Pavilion a1520n PC Desktop
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
Dell x50v won't turn on
while pushing the power button , push reset button for couple of seconds. hope that helps as that is what worked with mine.
Jun 11, 2009 | Dell Axim X50v Pocket PC
My Laptop Won't Turn On Even When I Push The Start Button
try pulling the battery out then with the power supply connected see if it starts, if it does then your battery is bad and is bringing down the power from the power supply.
Jun 02, 2009 | Toshiba Computers & Internet
TV wont come on
Check fuse.
Is this a LCD, Plasma ect...
Do you have sound?
If LCD and you have sound use a flashlight, shine on screen check for faint picture. If you see picture the problem is the backlight has failed, check inverter board for blown fuse.
Jan 09, 2009 | Televison & Video
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Gateway 510 X (10272197) PC Desktop Logo
121 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
