Question about NEC DTU 8D-2 Corded Phone
Voicemail Probelsm When I try to transfer a call to a person's voicemail, it just rings. The voicemail never picks it up. It worked before so I don't know what has happened?
  • bhulbert Jul 30, 2008
    One of our extensions' voicemail stopped picking up recently. It just rings. Tried Resetting Feature LED (feature, 99, feature).
I found the solution in some notes I have. Press Speaker, 43, 250, Speaker and the voicemail will activate. 250 being our central voicemailbox, you will need to know what your company's is.
Posted on Jul 31, 2008
How do I disable ee home phone voicemail
try the following
send a text with the phrase remove voicemail divert to 150 will cancel the voicemail divert
(sending a text with the phrase voicemail divert to 150 will re-enable the voicemail service).
if that doesnt work ring EE customer service they can do it for you
May 03, 2017 | Lands Phones
As the receptionist I take calls and then transfer them to the person the caller disires to speak with. For example, if I am on a call and the person I am speaking with would like to speak with my boss, I...
A couple of things, but first. When you TRANSFER a call to your boss using the transfer button, he key to getting rid of the call is to hang up. But that's not your problem. When we install voice mail systems, we reserve 3 buttons; one for VM TRANSFER, one for 2 WAY TRANSFER, and one for VM RECORD. It's easier to link you to the OM of a TDA system than explain it, so here's the link
Pdf page 170 will give you the table for setting up your 94,91 and 90 codes for the above features.
Basically, you press PROGRAM, the button, and dial, for example, 94 500 SAVE to store the VMT . You use it by pressing that button while you on the call (no hold) and either dial your boss' extension or press his DSS button. If you use the 2-way transfer, you can actually put his number under one button and carry on a 2-way conversation with the outside party. Kind of like you would do with the old 'pink slip' messages.
Mar 16, 2011 | Panasonic KX-T7630 Corded Phone
When I am on a call and the person I am speaking with wants to be transfered to someone els' voicemail, how do I do this?
when in the call press the transfer button then you will hear a dial tone. Enter that person's extension and if they have their voicmail set up on their extension it should pick up and the call is transferred to voicemail
Mar 10, 2011 | Panasonic KX-T7630 Corded Phone
I have a Comdial Edge 120. When a call is transferred to an extension and is not picked up at that extension within a certain period of time, it goes to that extensions voicemail instead of bouncing back...
I'm not familiar wiht Edge terminology, but the idea is you set the transfer recall time to something less than the call forward to voicemail. It means that any calls to voicemail have to be direct transfers and there may be some auto attendant issues.
Oct 22, 2010 | Lands Phones
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Trying to change number of rings before voicemail picks up
This is done in station administration. F config side of the system. Do you have access to system programming?
Jul 21, 2009 | NorStar T7316 Corded Phone
Calls automatically go to voice mail
When you pick up the handset you hear a stutter dial tone? Forwarding or DND might be on.
Oct 16, 2008 | Avaya 5400 Series 5410 Phone
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Apr 29, 2008 | NorStar M7310 Corded Phone
NEC DTU 8D-2 Corded Phone Logo
438 people viewed this question
Top NEC Lands Phones Experts
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
