Ricoh 3310L Fax machine - 'Time to change PCU'
My fax machine has come up with a message that i don't understand 'time to change PCU'. I don't think it is the toner - it has been suggested that it may be the Printer Cartridge Unit??? Can someone please confirm this?? need to find a pcu for my savinfax 3725e
  • Anonymous May 05, 2009
    For about a month my Ricoh fax machine is stating "Time to change PCU"- What does that mean?
JayBlair
  • 328 Answers
SOURCE: Ricoh 3310L Fax machine - 'Time to change PCU'
You need a new drum. Photoconducter unit. Cost about 140.00 I sell them or you can shop on EBAY
Posted on Aug 10, 2007
blkghost
  • 46 Answers
SOURCE: Toner Cartridge reading has empty but have replaced toner
Try to see in the software if there is any reset option for the toner.
Posted on Nov 08, 2007
Logjam
  • 159 Answers
SOURCE: Time to change PCU
You just have to press the "yes" button. Watch the display. It says "Change PCU Y/N"
Posted on Mar 31, 2008
SOURCE: Samsung SF560.
make sure you have the correct cartridge as the SF560 & SF560R use different cartridges
Posted on Apr 30, 2008
tech435
  • 284 Answers
SOURCE: low toner message
sounds like you have a bent toner sensor. turn the machine off and take the toner out and place on the side
what you could try to do is grab a piece of paper fold it in 4 like so
__ __
|__|__| __
|__|__| then rip one piece like so |__|
then rip one piece off and fold that 5 times over it self.
look into where the toner goes in the middle you will see a silver bracket with a black round piece of plastic on the top left conner you need to put that piece of paper under that coner where the black circle is and turn the machine back on then put the toner in.
if this does not work you need a tech to look at it
Posted on Dec 04, 2008
What does time to change pcu mean?
Hi, PCU stands for photo conductor unit, most of us call it a drum unit. You should be able to order from any office supply. It is easy to install and will come with directions.
Oct 08, 2014 | Ricoh 3320L Laser Fax
Hello, I have a Ricoh 1160L Fax machine and I
my fax is ricoh1160L.This fax always one fault 'CRU fuse error'show the display
Jul 20, 2011 | Ricoh FAX1160L Plain Paper Laser Fax
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Time chance pcu
here you will find the manual read to resolve this issue, thank you,
http://pdfdatabase.com/ricoh-3310le-manual-repair.html
it counts to vote, have a wonderful day
Mar 25, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Jan 23, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Fax shows ''time to change PCU'' how can this be fixed?
you need to replace the Photo Conductor unit (drum unit).
Nov 17, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Time to change PCU- Ricoh 3310L
Go to this page http://www.ricoh.com/ and find the official ricoh service department for your area
Nov 07, 2008 | Ricoh 3310Le Fax Machine, FAX3310Le...
Time to change PCU
Mar 26, 2008 | Office Equipment & Supplies
PCU?
Hi the you will be able to purchase the PCU (Photo Conductor Unit) it is customer changeable so type in the following in google there you will be able to find a store that sells them.
Photoconductor unit for ricoh 3310
Thanks J
Jan 22, 2008 | Ricoh 3310Le Fax Machine, FAX3310Le...
Aug 10, 2007 | Ricoh 3310Le Fax Machine, FAX3310Le...
728 people viewed this question
jasbo
jasbo
