Question about Elna Quilter's Dream 6003Q
Bobbin winding Whenever I try to wind a bobbin the thread does not go onto the bobbinevenly. What can I do to get a smooth even tightly wound bobbin?
  • 323 Answers
On the top left side of your machine is a round thread guide which is supposed to create tension and guide the thread. Sometimes the thread comes out of this thread guide and causes the problems you are experiencing. Wrap the thread around this guide one time and you should have your problem resolved.
sewman7
Posted on Jul 09, 2008
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Nov 10, 2017 | Sewing Machines
Tip
Winding a bobbin correctly
The heart of sewing is producing a well tensioned seam and achieving this with any sewing machine will be difficult if you don't wind a bobbin smoothly and with even tension onto the thread. If you look at your bobbin and the thread on it looks all lumpy and uneven, then this tip is for you.
Each time you wind a bobbin, whatever sewing machine it is on, it is really important to keep even tension on the thread as it winds onto the bobbin. Many machines will have a little tension disc you take the thread around but your technique is important too.
Usually you take the thread from your spool of cotton on the right, across to the left on the top of the machine and around a tension disc, or through a thread eye, then back to the right to your bobbin winding spindle, if your bobbin has holes in it, then pull the thread tail up through a hole and pop it onto the spindle. Engage the spindle by pushing across against the stop. Now start winding SLOWLY while holding the thread tail up in the air until the core of the bobbin has been covered in fully and your thread has covered up the starting point to hold the beginning tail. Stop winding, and trim the tail off against the bobbin with a pair of snips. Now resume winding at 1/2 to 3/4 speed and do two things, one with each hand. With one hand put tension onto the top of the spool you are winding thread off - use the curve of your scissors handle into the indent on top. And with your other hand, give the thread a nudge as it winds onto the bobbin to ensure you wind fully across the whole bobbin evenly. Watch it carefully to ensure that you get a smooth even wind.
An analagy: if you wind the garden hose onto the hose reel really fast and let it go anywhich way, the hose will kink and wind mostly in the middle then the reel's full and you've still got half the hose to put away. Thread is the same, its been wound onto a spool by a machine in a very precise way; you want the same smooth evenly tensioned winding onto your bobbin so that when you stitch out the seam the thread is consistently fed off the bobbin.
Don't be tempted to wind flat out and just let it take its own path as you won't get good smooth bobbins of thread. And if you let the thread come off the spool at a fast pace the spool may bounce around, causing fluctuations in the tension on the thread. When you stich a seam, the thread will relax unevenly in your seam causing puckers and ho hum stitching.
Simple stuff but it makes a difference!
on Oct 02, 2011 | Sewing Machines
How do I wind sharing thread onto a bobbin on a LX-5500 brother sewing machine?
Generally, elastic thread should be hand-wound onto a bobbin. Hand winding allows the elastic thread to be wound onto the bobbin without any stretch prior to sewing.
Feb 22, 2016 | Brother Sewing Machines
The bobbin thread keeps breaking! It is very loose and then snaps?? I've replaced the needle to make sure it was sharp, I bought the highest grade thread I could find, adjusted the tension... then...
Sounds more like the way the bobbin has been wound, is it loose and uneven or tight and smooth. Is it properly into the tension spring? being loose doesn't sound right, a thread under correct bobbin tension is usually pretty firm.
Is it loaded into the bobbin holder the right way ?
Also check the bobbin itself hasn't been damaged in some way, not worn/bent. It needs to turn smoothly in the bobbin holder so if one edge has been bent a little this will cause problems.
When winding bobbins, you must have tension on the thread so it winds smoothly with consistent tension on the thread. Most machines have a little tension disc on top or the thread goes through the regular tensioner in order to achieve this. But I always wind bobbins at about 3/4 speed and also add a little extra tension by holding my scissors handle on top of the thread spool so it doesnt bounce around. Also start winding with a little tail pulled through a hole on top of the bobbin and wind until this starting end is covered, then stop and snip off the tail. Then continue winding and watch the thread, giving it a nudge so that it fills evenly across the bobbin, not just all in the middle.
Think of it like the garden hose reel; if you wind it really fast the hose all goes into the middle of the reel, then jams up and you can't get the whole hose onto it. Same thing, wind smoothly and evenly across the whole depth of the bobbin so that the thread is smooth and even. Then when the thread feeds off it will be smooth evenly tensioned and should stitch out evenly.
There is some good trouble shooting information on this page too which might help you to work out what is causing this thread breakage.
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Jul 17, 2011 | Necchi Sewing Machines
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
The tension on the bobbin is giving big loops and then breaking
This could be one of the following:
  • wrong bobbin for the machine
  • bobbin loaded the wrong way - must rotate anticlockwise when you pull the thread
  • thread not into the tension spring/device on the bobbin holder correctly
  • bobbin wound badly, uneven tension, loose or uneven across the bobbin
  • poor quality or old dry brittle thread could cause the breaking (but the loops is definitely tension issues).
This is a top loading bobbin machine machine and you can download a manual from
http://www.singerco.com/accessories/manuals.html
Here is the threading diagram from the manual.
tally_girl_21.jpg It is important to click the thread down into the tension spring on all top loading bobbin machines and then pull gently on the thread to check that it is under tension, you should feel firm resistance when you pull the thread. If not, then take it out, and try again.
Other thing to look at is how the bobbin is wound. It is necessary to wind a bobbin smoothly and with some tension on the spool as the thread comes off it. Best analogy is the garden hose reel. If you wind it up and don't control where the hose goes onto the reel it will all lump up in the middle, and you won't get all the hose onto it. And then when you go to pull the hose out, it will jam and be difficult to pull. Same with bobbin thread. You want a nice neat even fill across the whole width of the bobbin, not just the middle. To achieve this make sure you use the bobbin winder tension disc when winding. Also use the spool cap on top of the thread spool to stop it from bouncing around as it unwinds - the thread will then wind off around the spool cap and this keeps it running smoothly and not twisting and jerking. If you don't have a spool cap then put the curved handle of a pair of scissors on top of the thread spool to tension it while you wind the bobbin. Also watch the bobbin as it winds, give the thread a nudge with your finger to control the fill onto the bobbin so it winds top, bottom and middle of the bobbin evenly.
I would suggest the following:
clean out the race following the manual directions to remove the bobbin holder, clean in this area, replace it. Wind a fresh bobbin and then load it into the machine, following the manual instructions carefully. Also thread the top of the machine following the manual, put in a new sharp needle from the pack, turn the top tension dial to a medium number (often 5 if dial goes from zero to 10).
Now test sew again. Look at the seam, if you have loops on the bottom of the fabric, underside, then the top thread tension is too loose or not in the top tension discs fully. Generally you should not need to adjust the tension on the bobbin thread for these machines.
Apr 13, 2011 | Singer 5050 Mechanical Sewing Machine
The bobbin winds really loose and uneven and then gets caught up when I'm sewing. I've checked I'm threading it correctly when winding... seems to be worse with polyester and embroidery thread. Help!
You need to keep tension on the thread spool as you wind the bobbin to avoid this from happening. Also, is there a little tension device to take the thread around between the spool and the bobbin winder? Some machines have a little silver button tensioner purely for bobbin winding to keep the thread flowing smoothly.
But I always do the following anyway just to ensure a smooth bobbin. Take the thread from your spool, through the eyelet or tensioner, then back to the bobbin and put the tail end up through a hole in the top of the bobbin. Now put the bobbin onto the winder and click it against the stop. Place the curved handle of a pair of scissors onto the top of the thread spool and apply some gentle pressure to stop the spool from bouncing and jumping while winding off. Keep doing this through the winding process.
Start the bobbin winding mechanisim, its a button on my Janome 6500, yours might be a little different. HOLD the thread tail until you've got coverage over the whole bobbin area catching the starting point. Stop, trim the thread tail off top of the bobbin with scissors, then restart winding again. Watch as the thread winds and give it a nudge with your finger tip to the top or bottom so the bobbin winds evenly across the whole spool's width.
Best analogy here is when you wind the garden hose onto the reel, if it goes on all over the place you never get the whole length on neatly, but if you wind it on neatly in an even tight coil across the spool, then back again, then repeat, you get a tidy hose. But just wind madly, it all builds up in the middle, you can't get it all onto the reel, and it won't pull out nicely next time you need it. Same thing with your SM thread.
Polyester and silky embroidery threads will be worse too as they are silky, so if the thread hasn't been wound on smoothly and under tension, then it will "collapse" with gravity, then when you use the bobbin, the thread is going to be caught on itself, will feed unevenly and be stretched, then loose, giving you less than perfect stitch tension.
My other bobbin tip is store the bobbins in a plastic bobbin tray so they are lying on their edges and under a cover. Keeps them neater and they are less likely to unwind stray threads around your sewing cabinet if you store them on the spool pins build onto the cabinet door - and it keeps the thread dust free. But I do not keep thread on bobbins for long, prefer to wind a fresh one off a new spool when I start a project and can usually complete a garment with a 3/4 filled bobbin, use the remaining few metres for handsewing, then junk the rest. Then I put the thread spool that is left back into a sealed takeway container to keep it away from UV, dust and moisture.
I hope this assists you with your machine and certainly if this doesn't resolve the bobbin issues, then I'd suggest you visit your dealer and ask them to demonstrate the technique on your machine to see if there is a technical issue with it.
Apr 10, 2011 | Elna Xplore 8600 Computerized Sewing...
Bobin jumps when sewing
Could be in around the wrong way, poorly wound or not under tension correctly. Or even the wrong bobbin for this machine.
I suggest that you check that the bobbin is correct, ie do you have several that came with the machine and are they all the same in shape and diameter? Consult the manual if you have one.
Nextly, wind a fresh bobbin taking the thread from the spool through the tensioner (if your machine has one on the top) and then onto the bobbin. Keep a little tension on the thread spool with the handle of your scissors to ensure that the bobbin winds smoothly and evenly. Use your finger tip to nudge the thread to fill all areas of the bobbin. You want a neat smooth wind so the thread will then flow smoothly off the bobbin when it is in the machine making stitches.
Now, load the bobbin into the bobbin holder or bobbin case as per your manual, ensuring the thread is correctly into the tension spring and bobbin is rotating the right way around.
Now thread up and test sew again.
Apr 09, 2011 | Brother Sewing Machines
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Nov 09, 2017 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
77 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
