Question about Kenmore Ovens
I have a Kenmore oven model 3627361193. The oven was not working but the broiler did ignite. I replaced the ignitor for the oven. I then replugged the oven and attempted to turn on the oven. I heard a loud click and it tripped the circuit breaker. I then rechecked the fittings on the igniter, made sure there were no shorts and tried it again. Nothing. Now even the broiler does not work. Is there a fuse or breaker somewhere in the oven? I've looked and haven't been able to find one yet. The igniters for the stovetop and clock are working. Thanks
  • Tim Marrin Dec 30, 2010
    Thanks for your help. I guess I have an older model. There aren't any numbers on the face of the oven. Just buttons to increase and decrease temperature and clock. If I understand correctly, there shouldn't be a fuse or breaker on the oven. I should first replace the thermostat probe and see if that solves the problem. Is that correct?
    Thanks,
  • 4,323 Answers
Hi
This issue can occur due to faulty relay on the oven control board or due to a faulty oven temperature sensor. Use a multimeter to check for resistance of the sensor, use RX1 or RX10 setting. Make sure that the reading of the oven temperature sensor is between 1080 and 1120 ohms at room temperature. Please check part#43 (temperature sensor)---
Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 31, 2010
    President:
  • 1,654 Answers
As strange as this might sound, your clock and control panel board are probably bad. These tend to go out just like you explained and the problem can only be fixed if you replace the clock and control panel. It needs 240 volts to heat the oven, if that clock/timer control is only sending 110 volts to it, then you would need a new clock/timer assembly.
You can try a reset, but there is no reset button on the oven, Press the "7" button on the Kenmore Elite keypad.
  • 2 Continue holding the "7" button for at least six seconds until a single beep sounds.
  • 3 Press the "Start" button on the keypad once. This will reset the oven back to the factory default settings.
  • Did you get any error codes?The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
    This is usually caused by a failed oven temperature sensor probe.
    Replacing this component will likely fix your problem.
    You can order this part from www.searspartsdirect.com website.
    If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
    On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
    Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
    Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
    On some models, you have to remove the lower back oven panel to access the sensor probe.
    If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
    If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
  • Posted on Dec 30, 2010
    • Dcramer531
      Dcramer531 Dec 31, 2010
      Here are the sensor and control board picture for your model, they can be purchased at sears.
      I would try the sensor first because it is the least exxpensive and easiset to replace.
    Kenmore gas oven 790.7862 will not light but broiler does, igniter works does not seem to get any gas
    HI,
    Just because the ignitors glow doesn't mean the work. With that being said, the ignitors sold job is to ignite the gas and open the safety valve to release gas. I the ignitors are weak (common) they will not allow the gas to be released. So without a amperage meter, you will be unable to see this. With one you can detect a weak ignitor with reading of (2.8 or lower), to function properly you need readings of (3.2 - 3.6).
    When the ignitor is questionable, replace them, most units have two.
    Good Luck
    I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
    Sep 10, 2011 | Kenmore Ovens
    Kenmore oven model 79071442601 oven and broiler don't work, igniter comes on but no gas, hooked voltmeter to wires at gas valve and only reads 2.4 ac volts when turned on, is this igniter problem/
    hmmm im a bit conflicted here the ignitor does indeed come on yet there is only 2.4 vac to it hmm,it operates at 120vac and there is no way the ignitor would come on at only 2.4 vac so i suspect that your misreading the meter and it is 110-120 vac and that eliminates all other possibilites and the ignitor is weak is weak and not pulling the required 3.2-3.6 amps to open the gas valve if you have a amp clamp is to one of the wires and if it is below 3.2 amps replace the ignitor then enjoy your baked meal
    Jul 22, 2011 | Kenmore Ovens
    Oven won't ignite
    most likely you have a bad ignitor.take out the racks and remove the floor,you'll see the ignitor,turn on the bake,the ignitor should glow and the flame should lite within 40 seconds,if it doesn't change out the ignitor,even if it glows that doesn't mean the ignitor is still good change it out.let me know what you find and next time send model number
    Jun 20, 2010 | Kenmore 33169 Gas Single Oven
    Kenmore gas oven; range&broiler work, not bake cycle-bad ignitor?
    Well there are other parts that control the igniter,but if you can remove the igniter and look for any cracks.Most are hard to find so you may need a magnifying glass.Any crack no matter how small will keep it from glowing.The gas will not flow until the photo senser has detected the igniter glowing for several seconds.You can get a parts breakdown at SearsPartsDirect.com.Well hope this helps.
    Feb 02, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Broiler light, oven wont
    You are probably right though often the ignitor will glow, but just not hot enough for the valve to open. I would definitely try replacing the ignitor first, it is much cheaper than the gas valve and those valves rarely go bad. It is possible that the thermostat is not sending 120V to the valve, and thus the ignitor but less likely.
    Jul 21, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Oven will not light but broiler works. Ignition Module turns red when you turn on oven but no fire
    there is a small bathtub shaped can that the gas line goes into under the broiler this releases the gas to the ignitor module replace it
    Apr 21, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
    My Kenmore oven wont ignite. The broiler works
    The problem is your bake ignitor. The following link explains:
    http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
    The bake and broil oven features each have their own separate igniters and operate independently of one another. That explains why the broiler still works. They are, however, fed from the same gas source. So...the logical conclusion would be to replace your bake igniter (the no glowing is usually a dead give-away).
    Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Prices can vary amongst sites, so shop around for the best price. The sites I provided to you, I found, tend to offer the best service and prices.
    If you have questions along the way, or require addtional service, please let me know. I hope you find this information helpful.
    Feb 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore oven and broiler do not work
    Hi and welcome.
    Just because you see a glowing ignitor that does not mean it is "good". You need to check the circuit amperage to be sire. Weak ignitor are ultra-common for the appliance technician to see. The minimum amperage required to open the gas valve is around 2.9 amps. if you have access to an amprobe, read the amperage draw thru one of the ignitor's lead and you will see very quickly if it is good or not. Bad oven valves are much less likely than a weak ignitor. Many do-it-yourselfers replace the oven valve because they see the ignitor is glowing and assume that the ignitor must be good.
    Hope this helps.
    Dec 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore Oven
    The igniter may need to be replaced again. The only way to know is to test it to see if it has enough amperage to light the gas. If it glows, but no lighting of the gas, get it tested.
    Mar 21, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Kenmore 75358 -oven not lighting
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    Feb 26, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Ovens Logo
    249 people viewed this question
    Top Kenmore Ovens Experts
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
