I have a mitsubishi projection tv vs 6021 manf date may 1998. I have no picture no audio. the power swithc light is green and contiously flashes. Deos any one know what is wrong with it. thank you Denna
  • 70 Answers
3 things will cause this and one wil be the problem. first off flashing green indicates protection mode.
Check for a faulty vertical chip. usualy removing it and briefly turning on the set will make the set work with a line across the middle of the screen. If the chip is the fault please replace the capacitors around the i.c as the fault will reaccur.
next check the horizontal out transistor , it should not be shorted between base and collector. if so check for dry joints around flyback trany and horizontal stage circuit.
last is the 8 volt regulator that supplies the micro its power. located on the power module.
Posted on Jul 07, 2008
Mitsubishi VS-45605 rear projection tv
If the green light is not lighting up, you will need to check out the standby power supply inside the TV set, or if this set has a DM board, you will need to change the capacitors. Good Luck
Jul 13, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 60" Model VS-6047
going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Feb 11, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
