Question about Kenmore Dryers
My dryer has no heat. Is there a fuse to this dryer model and where can I fined it?
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
Dryer won't heat. How can I keep troubleshooting?
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
May 15, 2017 | Kenmore Dryers
Model 66944 Electric Kenmore Dryer has no heat. Runs but doesn't get warm. Check basement fuses and they are fine. What else can I do does this model have fuses on board?
your heating element is out,or one of your hi and low thermostat, or possiby a burned wire leading to these items,best option is to hire a professional,this can all be tested with a tester
Jan 23, 2011 | Kenmore 66942 Dryer
Fridgidaire dryer model aeq7000eso isn't heating
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 18, 2010 | Frigidaire AEQ7000ES Dryer
Will not heat
Check your house fuse/circuit breaker panel. The dryer runs off 2 circuits -one for heat and one for the motor.
Mar 14, 2010 | Dryers
How to take off heating element. The fuses seems
do you have a meter?pull one of the wires off the heater and read it out,you could have a bad thermal fuse,a,bad high limit t stat or a couple of other problems,check to make sure you have 240 volts coming in at the back of dryer at the block where the cord connects to dryer,there are 2 house fuses that can go to dryer and one could be bad,next time send model number,if the filter is on top then go to the back of dryer,if the filter is inside,take off the bottom panel and check out the thermal fuse there,it's located on the blower wheel housing it's either 3392519 or 3390719 depending on model number,if you need more help let me know,good luck
Feb 18, 2010 | Kenmore Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer tumbles but not heat
here is the link for the wiring diagram... heat is definatly on a separate circuit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
May 25, 2009 | Maytag MDE308DAYW Electric Dryer
Dryer won't heat
I know you said the fuse box is fine but check and see if you have 220 volts at the dryer cord we need to start there let me know what you find
bill
Jan 10, 2009 | Dryers
Dryer works no heat not breaker
hi!! you must always check for voltage first. If you have 120 volts and 220 present then its you thermal fuse that is bad.its a small white oval fuse located near the dryer blower replace that and you should be fine..Good luck..
Jan 03, 2009 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
