Question about Gateway GM5420 Refurbished Intel Desktop Computer - Intel Core 2 Duo E6300 1.86GHz , 2GB
Need A processor fan motor for mo. gm5420 - Gateway GM5420 Refurbished Intel Desktop Computer - Intel Core 2 Duo E6300 1.86GHz , 2GB
    Sergeant:
  • 320 Answers
Hi ome, I looked up some specs and found a pdf file that has photos of the cpu fan. It looks to be a standard fan that you should be able to buy at Radio Shack. Remove the fan and take it with you to Radio Shack and they will be able to match it up. Here is the link to the pdf file on your GM5420:
Alternatively if you want on buy one on line, the Core2 Duo has a LGA 775 socket type and you can find fans at the link below: Hope this helps
Posted on Dec 30, 2010
Blower fan not working at all 2004 Buick rendezvous
Which system ?
HVAC Systems - Manual HVAC Systems - Automatic
If automatic it's probably the blower motor control processor .
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, Blower motor speed signal, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module sends the commanded blower motor speed to the control processor through a 0 to 12-volt linear ramped blower motor speed control circuit. As the blower motor speed control voltage increases, the blower motor speed increases. The control processor sends the actual blower speed to the control module through a 0 to 12-volt blower motor speed signal circuit. The processor supplies 12volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Nov 19, 2016 | Buick Cars & Trucks
Missing variable control voltage on the blower fan control module on a 2008 Buick lucerne
What are you using to test this control signal ? Were you on right wire ?
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module provides a pulse width modulation (PWM) signal to the control processor in order to command the blower motor speed. The processor supplies 12 volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Chevy Trailblazer EXT Blower Motor Won Turn Off The blower motor in this video don't shut off , but he show's how to test the PWM signal right !
Your blower motor control module is probably bad , or HVAC control panel is bad , or a wiring problem !
Sep 26, 2016 | 2008 Buick Lucerne CXL
Why does my GM5420 Tower appear to start up normally, but it doesn't register my screen?
The motherboard or the video card might be defective. Check on that side. If you have an installed video card, try replacing it.
May 28, 2014 | Gateway GM5420 Refurbished Intel Desktop...
Why does my GM5420 Tower start up, but doesn't Read/Register screen?
I am not familiar with Gateway machines but this should work for most computers. You will have do some reading up. Yes it's probably a VGA (15 pin D-sub) the connector is often blue but can be any colour)
If your mouse/k-b etc are wireless they may need fresh batteries.
It may be the graphics facilities on your computer are u/s. It's quite awkward to solve this problem because you can't see what you are doing. You might try drivers for the monitor you are using (do not pay for these and be careful to void websites which are sources of adware or other malware) though this is unlikely as basic graphics are supplied in the BIOS
Try "gateway" support, or the "gateway" or other computer forums.
Read this http://www.pcguide.com/vb/showthread.php?70528-Upgrading-Video-Card-on-Gateway-GM5420
If there is a peripheral graphics card and your machine has on board graphics / video enter the BIOS (read up) and choose on - board video.
Try a graphics card (or on-board, or a different one known to work - see one of the many articles on how to set up a graphics card) Borrow one.
Essentially my course of action is try an alternative graphics facility to the one you have at the time of your post.
(Ihave just looked at the specification for this model at http://www.cnet.com/products/gateway-gm5420-core-2-duo-e6300-1-86-ghz-2-gb-320-gb/specs/
and it has on board Intel graphics default. Assuming the hasn't been an graphics 'upgrade' on your PC
You might find this webpage helpful (it has a troubleshooting section in the service manual)
http://us.gateway.com/gw/en/US/content/drivers-downloads
19.December.2014
The heater fan won't stop, even if i turn off the key the fan still turn, unable to control it, it only turn at one speed (not the fastest one), i check the resistor it look like there's a short in it, the...
Your impala doesn't have a resistor , it has a blower motor control processor and it doesn't work the way you think it does
The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module provides a PWM signal to the control processor in order to command the blower motor speed. The processor supplies 12 volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
HVAC Blower Motor Circuit
May 27, 2017 | Chevrolet Impala Cars & Trucks
Desktop will not boot at all. Turn it on and it will begin once and quit. Second attempt it begins to run ( fans ) at what seems half speed. Occasionaly it will start with fans at full speed. It will not...
Sounds like memory to me, if it has more than 1 stick of memory try using just 1 at a time to eliminate the faulty 1. If theres only 1 stick try replacing it. Cheers from Scott and plz vote
Jan 14, 2011 | Gateway GM5420 Refurbished Intel Desktop...
I bought the bravetti platinum pro blender-food processor used
I am not familiar with repair shops in Springfield, MO. But, I noticed a relatively inexpensive listing on OVERSTOCK and their shipping is very low.
(if this has been helpful, please give me positive feedback)
Jul 19, 2010 | Bravetti Platinum Pro Quad-Blade Food...
No display on my asus P4GE-MX mother board
hi! im in philippines also.. did you here some sound? o kaya meron kang narinig na beep? kapag meron kang narinig na 1 long beep pki check ung memory mo. bka LOSE connection lng yan. tpos try to reset the BIOS setting. mikita yan sa loob ng motherboard. malapit sa CMOS battery.. meron jan na 3 pin na my numbr 1,2 and 3. tpos my mkikita kng mliit na item na kumakapit sa 1 and 2 ilagay mo xa sa 2 and 3 tpos mg hintay ka lng ng 7-10 seconds then ibalik mo xa sa 1 and 2.. tpos try mo paandarin.. ^^
Feb 09, 2009 | ASUS Computers & Internet
Gateway GM5420 Refurbished Intel Desktop Computer - Intel Core 2 Duo E6300 1.86GHz , 2GB Logo
278 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
