Question about HP Pavilion 760n (P6320A) PC Desktop
I have a hp pavillion 760n. The screen will randomly go black. The power is still on when it does this, but when you try to push the power button, it doesn't do anything. You can hold the power button down & it still doesn't do anything. We eventually have to pull the power supply to get it to shut off & then it turns on no problem most of the time. Other times, it will give an error message.
  • HP Master
  • 2,009 Answers
Ohhhh that is OLD LEGACY gear. see yours here, RETIRED>?
x2 what message , pretend helper are blind as all are in text box.
does that Desktop monitor (no model stated) does its OSD screen work, (front of monitor) push menu key, see?
if yes monitor may be ok.
next is PC.
is the pC with 1 vga jack or 2?
if 2 try both jacks with your VGA cable. (wink wink)
more simple tests. ("do anything" to me means silent )
  1. monitor power on, OSD works. on demand (menu button)
  2. PC power on, fans run, do that hear them ever clean the beast in 10 years? or more>?
  3. does the Monitor show NO SIG or NO SYNC?
  4. does the CD eject work.?
  5. listen to that old hDD with ear, silient?
  6. no, no,no, then the PSU is bad.if its fan is dead it is dead .
  7. i can list 10 or more causes but wont. until above is answered. (like mobo modules shorted or shorted hdd /cd drive or shorted VGA card)etc, etc, its computer, not a toaster. -ergo complex.
  8. tell more get more.
  9. what OS? is this XP (the virus magnet)
Posted on Aug 04, 2017
  • 4 Answers
tell me if there is something i need to know like: what were the things that you've doing with your computer before the problem happened?? are there any recent hardware/software changes?? tell also your OS- is it XP or Vista...
first, let's try to check if the problem is with the monitor or not,okey? try unplugging the monitor blue connector at the back of the tower.and make sure that your monitor is turned-on.If you can see a colored bars monitor is okey.if not, try a known good monitor...if it woks the problem is with the old monitor.(resolved)
2 (if not)
Now, complelely turn off your computer and try reseating all the cables, and your hardware components such as memory,video card,IDE cable and so on. but before doing so, unplug the power cable and then push the power button to drain the power.after reseating everything, plug back the power cable and turn on computer.try listening to the tower,tell me if you can hear some beeps also.
if no video issue is still there, try putting a known good video card if you have any.if a known good video card works then the problem is with the old one..
if the problem is still there after everything that you've done try calling the manufacturer. this is lead to a motherboard problem but try to call them first.
Posted on Jan 17, 2008
  • 138 Answers
SOURCE: Supply Memory - Error on Black
A supply memory error is the smart chip on the cartridge. It can also be a physically damaged or locked / froze catridge. In this case the machine is identifying the black cartridge. The first thing to do is replace the cartridge (black).
If it's missing or has a corrupted smart chip lots of weird errors can result but they will usually still direct you to the specific cartridge to replace. If it's a refilled or remanufactured cartridge I would HIGHLY suspect that is the issue.
To locate the smart chip to see if it has come loose, see the picture below:
It's the green little computer board in the picture. Make sure it hasn't come loose. Below is a close-up of the chip. If it is a remanufacture or refill it should look slightly different than shown in the picture as the picture shows an original HP chip. If it's the exact same and a refill, return the cartridge to your supplier.
Hope this helps you. If so hit it with a FIXYA. If not, try to get the printer to print a configuration page or error report and let me know the last couple errors shown by numbers. (Full numbers, like 10.10.1000 or 13.02.05.)
Posted on Sep 03, 2008
  • 8 Answers
SOURCE: HP Desktop power up problem
Bad ram probably, units do that all the time at my job. Most of the time, it is the power supply that does not have enough power to invest into all hardware that makes your pc. even if you had a 400watts power supply, the next time you are buying a power supply you should do some kind of upgrade. 600 watts or more. If you have a high end graphics card then you are indeed in need of a new power supply. also check your cpu, its fan, check if it still seated properly, if there still paste on top of it to hel cooling it down, and protect it from statics. if you added new hardware, remove them and keep checking if it is working. To do manual diags, you need to take the unit apart. I would start by removing rams first, and check ram one by one, then hdd, then disconnect other components until i find the actual part. I am sure it is your powersupply, worst case scenario is you mobo is gone.(but it powers up and shutdown after all so let us hope you don't have a dead motherboard." and remove the dust please, dusty units do not run properly. Neim Le Legionaire.
Posted on Oct 19, 2008
  • 32 Answers
SOURCE: Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Posted on Nov 19, 2008
  • 1257 Answers
SOURCE: My hp dv9000 won't shut down completely!
Update windows using and see if you have all the latest drivers in device manager for all the hardware connected..If still not resolved then backup the data and perform recovery.
Posted on Mar 06, 2009
Blue Screen, Zig Zag Squiggily lines, black sceen and freezes
No, try to call the HP tech support for possible repair. call at 1-800-474-6836
May 09, 2010 | Computers & Internet
HP pavillion dv2700 clicking noise, black screen
try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
Apr 26, 2010 | HP Computers & Internet
HP Pavillion Entertainment computer (laptop)
now u put out to another monitor by cable if u see screen in there ur lcd have problem, if black too it from ur motherboard , checking
Jan 14, 2010 | Computers & Internet
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
HP Pavillion DV8000 Laptop won't boot.
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
Click here for more information
Nov 27, 2009 | HP Computers & Internet
Hp pavillion dv9000 blank screen on start up
Sounds like you are having a video issue on the motherboard and that is not a software or easy fix. Most people have to change out their motherboards when it comes down it in regards to this type of activity.
Aug 30, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Sep 01, 2008 | Compaq Presario 5000 PC Desktop
H P Pavillion dv 9700, problem : screen is black like in sleep mode. I shut off, removed battery reinstalled battery, turned back on could hear the windows sound coming on but screen is still...
Try this -- it is called a Power Drain Procedure -- HP technical support helped me with this --
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Jul 08, 2008 | Computers & Internet
HP Pavilion 760n (P6320A) PC Desktop Logo
47 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
