Question about GPX Karaoke Party Machine
What cord do you need to plug the ipod into the karaoke machine
    President:
  • 2,047 Answers
This depends on the karaoke machine in question. Mostly the Ipod accepts a 3mm earphone jack and the karaoke is supposed to support the regular av in 2 pin jack. so all you need to do is get the single 3mm headphone jack to 2 pin av in jack. that should work perfectly.
Hope this solution has been helpful?
Posted on Dec 30, 2010
2 Suggested Answers
  • 5603 Answers
SOURCE: Need A/C Power Cord for
A good place to find cords and also adapters is at Thrift Stores.
Posted on Jun 06, 2011
Spb karaoke machine blown fuse 250volt 2amp changed it checked plug in wall still no power what could it be pls
You may have blown a component of the power supply, which is what took out the fuse in the first place. Probably will need a trip to the repair shop.
Aug 19, 2016 | Music
How do you get it to show the lyrics when using an ipod
lyrics are only included in karaoke files you have to download the karaoke version a song from iTunes
Jul 13, 2014 | GPX Karaoke Party Machine
Need A/C Power Cord for GPX Karaoke Party Machine , Model C1005RS
Jun 05, 2011 | GPX Karaoke Party Machine
I would like to connect my ipod How?
You will need a 3.5 mm to 3.5 mm audio cable, probably stereo to connect to the "line in" jack on the back.
Note: You will NOT get lyrics ONLY the audio will come through as IPOD does not store lyrics.
Jan 29, 2011 | GPX Karaoke Party Machine
How do i connect my ipod to the machine?
You use a Stereo splitter cable from the IPOD to two plugs than connect to the AUX inputs on the back.
Note that this only will amplify the IPOD, the mic inputs will be disabled... PROBABLY that is not what you want... but it is the way it works.
Jan 16, 2011 | GPX Karaoke Party Machine
How do you hook the i pod up to the machine, we cant seem to figure it out?
You would have to get a 1/8 inch to dual RCA plug stereo SPLITTER cable and connect to the jacks on the back.
You will be disappointed however, as the unit will disable the microphones when you send music into the jacks... The thing just acts as a straight amplifier in this mode.
The only way to have a microphone active AND the IPOD is to sacrifice one microphone and use a mixer of the IPOD stereo output into a mono line into one of the microphone jacks. You can build your own mixer by using a couple 1K ohm resistors from each of the IPOD's output (stereo) leads into a single plug to plug into where one of the microphones plug in. You cannot tie the two leads from the IPOD together or each side of the stereo would fight the other causing distortion, hence the resistors prevent this.
Dec 29, 2010 | GPX Karaoke Party Machine
We are trying to use the Karaoke Machine and the words don't display. And we don't see any audio input to connect the ipod.
You would connect the IPOD to the RCA jacks on the back, HOWEVER the audio through there cannot be used for Karaoke. Te only other possibility is to mix the stereo channels of the IPOD and run them into one of the MIC inputs.
To get words, you must buy special Karaoke CD's that have the music and the lyrics. Search for sellers of the disks using Google.
Dec 27, 2010 | GPX Karaoke Party Machine
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
GPX Karaoke Party Machine Logo
718 people viewed this question
Top GPX Music Experts
Michial Gueffroy
Are you a GPX Music Expert? Answer questions, earn points and help others
