Question about Hisense Televison & Video
TV LCD model hslc8129hdi remote controll not working ,new batterys,still not working,only mute is working (model hdi 100 )
    Sergeant:
  • 349 Answers
If only one function on the Remote works it probably needs repair of some sort.
Remotes are delicate things which can easily be damaged or broken by dropping them, or by spilling fluids such as soft drinks over the keypad. Old batteries can cause internal corrosion of metal parts. I have repaired some remotes successfully but many were beyond repair. The best solution in event of failure is to purchase a replacement of the original (new or second hand)or a multifunction remote which may have the code for your Tv or other apparatus in its memory,
Posted on Dec 10, 2011
I havea 46" sanyo model dp46841 lcd tv but the tv wont respond to the oem remote or universal remotes ?
Sounds like the infra-red sensor inside it is either damaged or it do not get proper voltage to work. Check it. If it get proper voltage/s and still not receive any infra-red signal from the remote control, replace it. The part in discussion will look somewhat like this.
25758228-54zq5khwu0nuxgxnhh2yrt4a-2-2.jpg Prior the replace this component, make sure that the remote control you're using works properly, and do emits infrared light rays, during each button presses on it. Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jun 23, 2015 | Sanyo Televison & Video
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
How do you unmute a toshiba tv
Check your remote control for its infrared emission. If the remote does work for half mute, an other press must make the TV to full mute, and an other press the TV should be unmuted. Check the remote with new batteries.
Jun 18, 2012 | Toshiba REGZA 47HL167 TV
Need new remote
Why not phone Hisense and ask them. The phone number number should be listed in your directory and they will tell you where the Hisense outlet is to purches .. and u can ask them about a universal one
Jan 27, 2009 | Hisense TL1700 17 in. LCD Television
Remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Nov 16, 2008 | Samsung AA5900213A Remote Control
Remote programing for TV after changing batteries
HOW TO PROGRAM GE Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Aug 03, 2008 | GE JASRM24912 Remote Control
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
147 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
