Question about Treadmill Doctor Weslo Cadence 1020 Treadmill Rear Roller
Not reading mileage? battery good - Treadmill Doctor Weslo Cadence 1020 Treadmill Rear Roller
    Novelist:
  • 128 Answers
Remove the motor cover. Check that the speed sensor (found on the frame near the pulley)is as close to the pulley without making contact as possible. Check the pulley for the small round magnet. Make sure it is present. It may have come loose and is now attached itself to the metal frame.
If all this checks out, the speed sensor may be defective.
Posted on Dec 30, 2010
On start up, why no rev counter, speedo or mileage reading on display?
I would try new rev counter cable same as speedo with mileage reading try just unplug the battery for 30 secs, plug it back in and hopefully it will reset itself. worth a try. Or maybe get new battery maybe yours loses voltage over time so can't cope with all electrics on bike.
Apr 04, 2016 | 2010 Honda CB1300SA
How can I reset OIL MAINTENANCE REQUIRE RESET UNFINISH message on Toyota Landcruiser 2010 diesel?
The sequence should be: Depress and hold the mileage reset button on the gauge cluster. While holding it in, turn the ignition key to the run position ( do not start the engine), You will see the mileage read "0000000" for 5 seconds, and then see the mileage return. After the mileage returns, the "Oil Life" has been reset. If you have the owners manual, it will be inside. Good luck.
Dec 07, 2013 | Cars & Trucks
Will not hold charge and voltage gage is not working
Is the alternator putting out a charging current when running? Measured at alternator then at battery. If no at alternator, replace alternator if high mileage, if low mileage replace regulator. The part the harness plugs into.
If yes at alternator and no at battery, check for continuity across ammeter and check the voltmeter for a short. The ammeter should read essentially zero ohms and the voltmeter should read about 15,000 to 40,000 ohms when measured with an analog ohm meter.
If those check okay, check for a wiring fault or a blown fuse on the power distribution block or a broken fusible link. Fusible links can be checked by gentle tension on them, those that have failed will pull apart.
Jan 18, 2012 | Cars & Trucks
Gas mileage reading more than what in the car
The car possibly needs a service and good tune-up. Also take into consideration that an older car will never give the gas mileage advertised for a new vehicle.
Jan 25, 2011 | 1994 Lincoln Town Car
I have a 2004 trailblazer LT. When I turn it off and later on start it up the clock has reset and the mileage has gone from travel mileage to total mileage. This apears to be an electrical problem, but...
Look for good ground connections. Your description sounds like low battery state of charge, then voltage goes too low on start up...Check charging system and load test the battery. Check ALL connections.
Aug 22, 2010 | 2004 Chevrolet TrailBlazer
THE MILEAGE ON MY 2002 GRAND AM GT IS SCRAMBLED,LED READ OUT,CAN NOT READ MILEAGE,WHAT IS THE FIX?
try to disconnect the battery for a lil bit 10 mins or so then see if it's still scrambled. if its still scrambled then it's toast.
Nov 10, 2009 | 2002 Pontiac Grand Am
Alternator only putting out 33 amps, also electric
I took the car to a small jobs repair shop. This lady happened to see the car and wanted to buy it "AS IS" she was aware of the problem and continued to want to buy the car, so she is the new owner and I no longer need a solution, Thanks so much, if I need help in the future I will consider your web site.
Nov 03, 2009 | 1998 Volkswagen Beetle
I got my hub assembly replaced and now my odometer is messed up
try unplugging the battery for 15 minutes and that should reset the ecu, good chance this will fix it otherwise it sounds expensive and diagnostically not fun good luck let me know what you find
Erik
U.S. Army
Oct 21, 2008 | 2002 Pontiac Sunfire
Treadmill Doctor Weslo Cadence 1020 Treadmill Rear Roller Logo
42 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
