Question about Hitachi Director's Series 57XWX20B 57" Rear Projection Television
Where is the headphone jack on a hitachi ultravision directors series
3 Suggested Answers
SOURCE: hitachi ultravision director's series 55"
****, sorry I don't have any solutions but I have the same TV, Hitachi 55HDX99 55 in. HDTV Plasma No Picture but the sound is ok. For about 6 months the picture would go out, I would unplug it for 10 mins and it would work for a week, but now the unpluging trick does not work any more. I have left the TV unplugged for 2 days and still no picture. lets stay in touch if one of us get any luck. my e-mail is pardeep@bangainc.com
Posted on Oct 21, 2011
  • 191 Answers
SOURCE: I have an issue with a tv It is a Hitachi Ultravision Directors Series model #55HDV99. It has picture and sound, but the color is not correct. The reds and blues are missing.
Check the connection between your cable box and tv.
You should have five rca cables connected. Red, yellow, and blue. the other red and white is for audio.
Regardless of them passing the eye test. Push on each end to make sure contact.
If that doesn't do it you may have a bad crt, but you are missing red and blue that would be two bad ones at same time. Not impossible. Could just be bad solder connections as well.
Posted on Dec 03, 2015
Dec 03, 2015 | Hitachi Televison & Video
Hitachi 42 PMA400e Plasma Tv.
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Is there any way to use head phones on a Hatachi L42V651?
Yes... and no. The TV should have 2 RCA jacks for audio out (red and white). If you get a "y cable" from your neighborhood electronics store, you could patch it through to headphones. The problem is that the volume level is intended for input into an amplifier, so you might be barely able to hear the sound on your headphones. If you patch the audio into an amplifier, then you can definitely use headphones.
Aug 11, 2011 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Hitachi 55" plasma Director's Series
Replacing the front glass entails completely disassembling the entire TV. Your best bet is to look for a broken TV with a good front glass.
May 28, 2017 | Hitachi 55HDX62 55 in. Plasma HDTV
Hitachi ultravision director's series 55"
I don't know how to fix your issue but I have the same tv with a cracked glass front. I would be interested in buying your tv for parts to replace my glass front if you are unable to fix yours. Please let me know. Thanks, Dan
dcgezz@yahoo.com
Jun 10, 2011 | Hitachi 55HDX99 55 in. Plasma HDTV
I have a Hitachi Ultravision Projection TV Model 57XWX20B. My TV will not stay on. I tried unplugging it, then plug it back in. It will then click once to turn on; then after 15 seconds it will turn off. ...
The power source detects an overload on one of its exits and shuts down to protect itself. The tv must be opened and tested by a knowledgeable person who can identify and replace the failed part.
Aug 22, 2010 | Hitachi Director's Series 57XWX20B 57"...
The set is a Hitachi Ultravision Digital Model #57XWX20B. The picture "Ghosts" red. When runnung the Magic Focus, it stops on the 5th red line and goes no further. In low light scenes, it blacks out in a...
The Convergence IC's need to be replaced. They are located on the Board to the right, mounted on a large heat sink. They should be replaced with STK392-150's. The original IC's are probably STK392-110's.
The Stk392-150 is a updated replacement. Be sure to use Heat Sink Compound between the IC's and heatsink because these IC's do draw alot of current and heat up alot. Also look for any heat stressed Resisters.
I hope this helps,
Sky Assoc
Feb 07, 2010 | Hitachi Director's Series 57XWX20B 57"...
How do you hook up the wii to the HItachi UT 42 x 902?
Problem: Hooking up Hitachi UT42X902 to a Wii
Solution: Even few technicans understand the issue because they have a hard time comprehending the Hitachi UT42X902 Director Series only has 1 HDMI jack and no RCA connections. I have both a Wii and UT42X902. At one point when I had a 4-way call with Hitachi, Nintendo, and Onkyo trying to figure this all out. So after several miss-steps, here is what I did and it worked…
I ended up buying an Onkyo TX-SR606 AV Receiver Amplifier-Tuner which has "uplink" capability. (Do not buy the TX-SR506 or other Onkyo models they do not have the right uplink capability to work the Wii on the UT42X902 Director Series, I already made that mistake and the store would not take the 506 back by the time I got everything I needed to connect the system.) I then bought a off Nintendo market Red/White/Blue/Green/Yellow HD or HDMI compatible (for the Onkyo side) on one end and Wii compatible on the other (sorry I don’t remember the technical name for the cable but they are pretty common and Best Buy and other electronics stores have it). I connected the cable to my Wii and the 5 ended side of the cable to the Onkyo. My CATV satellite box and DVD player are also connected to the Onkyo with Monster 1000HD (10.5 Mbps) HDMI cables. The Onkyo is connected to the Hitachi UT42X902 also via a Monster 1000HD (10.5 Mbps) HDMI cable. The Wii works perfectly with this setup. You may have to go into some menus to set up the sound (I do not have external speakers yet). Good luck. I usually am not on this site but will try to monitor this site every few days for the next few weeks so post is you have questions, and I will try to help.
Disclaimer: I am not a TV tech and do not sell, represent any TV, Receiver-tuner-Amp, websites, cables, TV channels, services or other related products, nor do I own stock in any of these companies. I am a mere mortal girl who wanted to use her Wii Fit on her big screen TV.
Jan 02, 2010 | Hitachi Director''s Series UT42X902 42 in....
Hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Director's Series 57XWX20B 57" Rear Projection Television Logo
1,533 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
