Question about Philips SPC230NC Webcam
When i try and install the software it gives me a "feature transfer error" for a traylcon saying "operation can not be performed on a file with a user map open what is this and how can i resolve it
I'm trying to install a game but it stops and gives me a feature transfer error, help me please.
Feature transfer error is usally self explanatory. This most often means there is a conflict with the game and the operating system you are loading it on. As well can be the hardware does not meet the minimum specs or the OS just compatible. Make sure the disk is spotless and if so could be a bad burn of the game. Try running the disk on another pc to be sure its good.
Aug 10, 2011 | Toshiba Satellite A205-S4617 Notebook
Having problems installing a canon mx340 on vista. Get "error occurred while files were being copied" and then "mp drivers could not be installed" Thanks.
Do you have the latest drivers? Download them and read the following:
uninstall the driver (using Add/Remove Programs in XP; Programs and Features in Vista/Win7), then with all programs closed, including your browser, and AV disabled, tried a reinstall.
In the environment where the Firewall software operates, as the printer detection using LAN communication is inhibited, the setup may not be competed.
Preventive action:
Disable the Firewall setting temporarily, or close the Firewall software, then, perform the setup.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 29, 2011 | Computers & Internet
Screen says "Printer error."
Welcome to Fixya
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
Thank you for using Fixya!
Mar 23, 2011 | Computers & Internet
No softwares like nimbuzz, ebuddy messnger , gmail are working on my phone . the error shows "your connection is not active for java applications" please help
Please contact your operator to get what are the best things they can give for this kind phone.
Performance of your mobile is depending of both your mobile and operator.
Also please double check the software you've installed in your mobile.
Nov 24, 2010 | Nokia 2730 Cell Phone
TI84 does not work!
Perform a manual Garbage Collect.
  1. Press [2nd][0] to access (CATALOG)
  2. Press [TAN] to jump to first command that starts with G.
  3. Find GarbageCollect
  4. Press [ENTER][ENTER][2:Yes].Garbage collection may take up to 5 minutes
  5. After garbage collection is finished retry transfering data to calculator.
Uninstall and reinstall the TI-Connect software:
  1. Go to Start >> Settings >> Control Panel or Start >> Control Panel and select "Add or Remove Programs".
  2. Locate the TI-Connect software in the list and then choose "Remove".
  3. Once the software uninstall process has completed, please shut down and power off the computer.
  4. Wait approximately 20-30 seconds and then reboot into Windows.
  5. Download and install the latest version of the TI Connect software from the TI Connect Software home page.
  6. Once the TI Connect software install process has completed, restart the computer before using TI-Connect.
  7. Attempt to transfer data to the calculator.
If these steps do not solve the problem contact TI
Jan 30, 2010 | Texas Instruments TI-84 Plus Calculator
Feature Transfer Error
Go into safe mode, edit the registry and remove all Panda entries. Also go into Configuration and uncheck Panda to startup if checked.
Try running the software while in safe mode and it gives a message that another software installation is detected and will be removed on startup, you'll know you need to find and remove files. It did not remove those mentioned above.
Feb 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Philips SPC230NC Webcam Logo
22 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
