Question about Echo Garden
Starts 3rd pull like it always has , but when ever i give it some throttle it chokes and dies. It will stay at an idle all day
  • 85 Answers
May need to adjust the carb if that doesnt help then the carb needs a kit
Posted on Jan 27, 2011
Wheeler wont stay running even after it's warmed up. Choking it won't keep it running either. This just started the other day. No issues up to this point.
Remove the play in the throttle by loosening the locking pin on the cable, then pull the cable tight to remove the play and refix the locking nut. Once the play is removed adjust the jet so that its steady at idle.
Dec 04, 2015 | ATVs
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
03 1200 only starts with choke all the way out and stays out to keep it idling, can not give it any throttle or it dies, push choke in any at all it dies Only has 1557.0 mils on it, fresh gas in it, vac...
Hey LD,
Bummer. Sounds like one of a couple of things... You did not specify what BRAND your bike is, but with the slide comment, I presume a Mikuni or similar type of carb.
So the artificial enrichment circuit is actuated during choke operation. This circuit only works with the throttle plates in the IDLE position. ANY throttle and that circuit drops out of the picture and the idle/slow/main jet circuits take control.
You COULD have a huge vacuum leak, and that would cause what you describe. Look carefully, squirt bottle some water around the intake/carb/manifold areas. Any change in idle is suspect. But you may not be able to achieve this, based on choke only operation.
SO, my thought is something is plugged in your carb. This happens with old gas and stagnation. Often the enrichment circuit will flow, but not the idle circuit. The only remedy is surgery. Typically you pull the carb(s) so you can inspect well on a bench. Pull the float bowl and look for foreign material of any kind. I have seen moss like growths in there... Perform an overhaul, with the long submersion, followed by flushing and high pressure air..
There is one other, fairly Bonsai method that works: You fire up the bike, with the air cleaner off.... Get as much engine speed as you can... One hand on the throttle, ready to open, and briefly cover the entire carb intake with the palm of your hand, at the same time, you need lots of throttle. What this does is sometimes dislodges a blockage. Really works well on lawnmowers. This takes a time or two for you to get everything synced, but you need lots of throttle and full intake air restriction. Sometimes works, sometimes not. I always worried about being successful as that means there is some chunk of something floating around somewhere in my carb. I would perform surgery.
I hope this helps.
Doc
Dec 01, 2014 | Motorcycles
Why motorcycle starts but only stays running when I open throttle?
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
http://www.motorcycleforum.com/59-motorcycle-repair/109746-only-runs-when-choke.html
Bike starts up idles on choke dies with choke off our when warm
Yamaha XVS13AWC Service Manual
OEM parts for Yamaha
Yamaha XVS13AW Owner Manual
May 06, 2014 | 2008 Yamaha V Star 1300 Tourer
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
Trimmer dies when you apply throttle
Sounds like it might be getting to much gas. What position is the choke in during all of this? If you're giving it throttle it may be flooding itself out.
Aug 26, 2009 | Garden
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
Garden Logo
139 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
