Question about Reddy Heater-170,000 BTU Kerosene Deluxe
With top cover off heater works, if you install top it will not work? I think thetemp senser is the problemp
  • 1,476 Answers
Leethmsn,
You have a classic Reddy Heater problem. They use an air bleed system to control the fuel pump pressure. When you take the cover off you have changed the air pressure and more importantly the pump pressure. You have a partially clogged air filter and need to replace it and set the pump pressure. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts and how to complete the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 30, 2010
We have a ge electric water heater - last night we set a new jug of detergent on top of it over the electric plate on the top of the unit - it had a hole ( small leak) in the bottom - it leaked all night...
You flooded water heater wiring compartment with detergent, and the wires were shorting so you turned off power and cleaned detergent. Now water heater doesn't work.
1) The heat from shorting might have tripped ECO reset button.
Open top cover on water heater, and push in red reset ECO button.
http://waterheatertimer.org/images/Jly-022-thermostat2-175.jpg
Be sure to re-install insulation and cover.
Other steps:
2) Turn off power. Remove wire nuts. Cut off copper ends of wire, and re-strip each wire so fresh copper shows. Make sure no detergent is on the copper. Use new wire nuts and twist very tight against copper wire.
3) Cut back burned ground wire. Remove ground screw and clean thoroughly. And then reattach clean copper to ground screw.
4) Turn power back on.
5) If water heater still does not work, then test across top two screws on upper thermostat for correct voltage.
http://waterheatertimer.org/images/Jly-022-thermostat3-175.jpg
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | General Electric Water Heaters
Heater core. where is it located and how do you replace it?
Heater Core REMOVAL & INSTALLATION For the removal of the heater core, which is located inside the heater-A/C unit assembly, first remove the heater-A/C unit assembly from the vehicle as described later in this section. Once the unit has been removed, use the following procedure to extract the heater core:
  1. Place the heater-A/C unit on a suitable work surface.
  2. Locate and remove one retaining nut from the blend-air door pivot shaft.
  3. To remove the top cover from the heater-A/C case, the crank arm must be removed.
  4. Disconnect the vacuum lines from the defroster and panel mode vacuum actuators and position them out of the way.
  5. Remove the 3 heater-A/C unit cover attaching screws, fastened upward at the defroster outlet chamber.
  6. Remove the 2 heater-A/C unit cover attaching screws, fastened upward at the air inlet plenum.
  7. Remove the 11 heater-A/C unit cover attaching screws, fastened downward into the housing. Then lift the cover from the heater-A/C unit.
  8. Remove the old heater core from the case. To install:
  9. Install the new heater core into the heater-A/C unit case in the same position as the old one.
  10. Place the cover onto the case and secure in place with the 11 retaining screws.
  11. Install the 2 heater-A/C unit cover attaching screws in the air inlet plenum.
  12. Install the 3 heater-A/C unit cover attaching screws in the defroster outlet chamber.
  13. Attach the vacuum lines from the defroster and panel mode vacuum actuators to the heater-A/C unit case.
  14. Install the crank arm and the retaining nut on the blend-air door pivot shaft.
  15. Install the heater-A/C unit assembly into the vehicle.
Oct 13, 2010 | 1990 Chrysler New Yorker
Is the heater core on a 1981 bronco in the engine compartment or the cab compartment
in the cab, but procedures are different depending on whether or not you have A/C. See below
1980-81 Comfort Vent Heaters, Without Air Conditioning
  1. Disconnect the heater hoses from the heater core tubes and plug the hoses with suitable 5 / 8 inch; (16mm) plugs.
  2. Remove the glove compartment liner.
  3. Remove two (2) spring clips attaching the heater core cover to the plenum along the top edge of the heater core cover.
  4. Remove eight (8) screws attaching the heater core cover to the plenum and remove the cover.
  5. Remove the heater core from the plenum taking care not to spill coolant from the core.
To install:
  1. Install the heater core in the plenum.
  2. Install the heater core cover (eight (8) screws and two (2) spring clips along the top edge of the cover).
  3. Install the glove compartment liner.
  4. Connect the heater hoses to the heater core. Tighten the hose clamps.
  5. Add coolant to raise the coolant level to specification.
  6. Check the system for proper operation and for coolant leaks.
1980-81 Standard & High Output Heaters, Without Air Conditioning
  1. Disconnect the temperature cable from the temperature blend door and the mounting bracket on top of the heater case.
  2. Disconnect the wires from the blower motor resistor and the blower motor.
  3. Disconnect the heater hoses from the heater core and plug the hoses with suitable 5 / 8 inch; (16mm) plugs.
  4. Working under the instrument panel, remove two (2) nuts retaining the left end of the heater case and the right end of the plenum to the dash panel.
  5. In the engine compartment, remove one (1) screw attaching the top center of the heater case to the dash panel.
  6. Remove two (2) screws attaching the right end of the heater case to the dash panel, and remove the heater case from the vehicle.
  7. Remove nine (9) screws and one (1) bolt and nut attaching the heater housing plate to the heater case, and remove the heater housing plate.
  8. Remove three (3) screws attaching the heater core frame to the heater case and remove the frame.
  9. Remove the heater core and seal from the heater case.
To install:
  1. Position the heater core and seal in the heater case.
  2. Install the heater core frame (3 screws).
  3. Position the heater housing plate on the heater case and install the nine (9) screws and one (1) bolt and nut.
  4. Position the heater case to the dash panel and install the three (3) attaching screws.
  5. Working in the passenger compartment, install two (2) nuts to retain the heater case and plenum right end to the dash panel.
  6. Connect the heater hoses to the heater core. Tighten the hose clamps.
  7. Connect the wires to the blower motor resistor assembly.
  8. Connect the blower motor wires.
  9. Position (slide) the self-adjusting clip on the temperature cable to a position approximately one 1 inch; (25.4mm) from the cable end loop.
  10. Snap the temperature cable on the cable mounting bracket of the heater case. Then, position the self-adjusting clip on the door crank arm.
  11. Adjust the temperature cable.
  12. Check the system for proper operation.
Oct 05, 2010 | 1981 Ford Bronco
Hi i am using wipro ex 1050 printer, it was showing out of paper, printing is not coming. how can i solve this problemp
switch off the printer then drag the printer head 10 times. then u switch on it will work.
Oct 01, 2010 | Office Equipment & Supplies
Paperjam in hp 1000 printer
two reason in paperjam 1200 series printer
one some senser not working so remove back sight cover and clean dust help with air blower.
and paper pick roller is not working
first you remove paper pick roller
and change direction of paper pick roller
means change direction means just opposite site use.
i think solve your problem.
Apr 10, 2010 | HP LaserJet 1200 Printer
Blowing coil fuse when key is turn on
more than one thing can blow the fuse, unplug the ingtion ciol and the distrubutor and then install a new fuse and turn the key on if the fuse blows then there is still something in the computer system or wiring that is crossed. Next also unplug the ECM itself and see if it still blows the fuse if it doesn't blow the fuse with the key on then plug in the disconnected items one at a time till you find the item thats bad or the wires that have gotton into troble. The oxogen senser heater can be on this circuit and there may be two oxoxgen sensers unplug them both and check that there wires haven't gotton into trobleagainst the exhaust pipes or other hot parts. If it doesn't blow the fuse with the oxogen sensers unplugged plug one in at a time and check fuse It'll run with the oxogen sensers unplugged. The sensers sometimes fail but more often the wire getts against the hot pipe and shorts to the pipe. repair wire and ty off and it may work just like it's supposed to.
Mar 22, 2010 | 1994 Suzuki Sidekick
Frost build up, Frigidaire FRT18K63CW top
The heater can be replaced $30-$40 appliance parts store. Make sure that's the part you need most places won't return electrical parts. Could be a defrost terminator also.
Jun 29, 2009 | Frigidaire FRT18KG3CW Top Freezer...
Valve pressure renault laguna
you must make sure the senser is the correct one.each wheel senser has to be correct.they are not the same.i think they are colour coded.say rear wheel wont work on front etc.sometimes inflate pressure to around 45psi on side that is faulty then let pressure down to correct level resetts the senser.otherwise think its renault dealer to reset computer
Feb 07, 2009 | 2000 Renault 181
Heater core replacement
This is a really easy job, disconnect the heater hoses at the firewall, go inside the truck on the passenger side there is a plastic panel/cover over the core, 6 bolts/screws I think, remove the cover pull the core, tops 1 hour, as job at work I did them in 20 minutes.
Oct 15, 2008 | 1998 Ford F150 Regular Cab
Maytag mav7600 agitator works and don't
Look at timer plug on harness for pins that are sticking out from side of timer plug, away from timer. See if they are all in the same amount. Sometimes one can work its way out so it won't make a good contact. Push in to plug if you find one.
Nov 14, 2007 | Maytag MAV7600 Top Load Washer
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
395 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
